Home > Puma (Tdci) > Which oil filter?
Zed
Which oil filter?
My 2.4 Puma engine was replaced and the new unit uses a later style cartridge oil filter. I want to do an oil change but can't make out the markings on the filter.
Do I need a specific filter or can I use the 2.2 type and if so what do folks recommend?
Post #775001 26th May 2019 7:57am
spudfan
Ireland
If it is the spin on type this would be it
https://www.advancedfactors.co.uk/lr058104...3255-p.asp
If it's the paper type I use this
https://www.advancedfactors.co.uk/lr030778...3111-p.asp
Both from Advanced Factors
https://www.advancedfactors.co.uk/service-...-210-c.asp
The above are from the service items listed for the 2.2 engine 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #775030 26th May 2019 11:23am
Zed
Thanks for your reply.
Yes the new engine uses a spin on filter. I’m hoping the type Land Rover use for the 2.2 will be OK for my 2.4. Is there any reason this may not be the case?
Post #775031 26th May 2019 11:33am
spudfan
Ireland
There is only one type of spin on metal filter listed so that should be it. I use Mahle filters and there is a Mahle spin on type listed on the advanced Factor site. https://www.advancedfactors.co.uk/lr104384...8843-p.asp
If you are still unsure e-mail Advanced Factors. They are a site sponsor and will give you a discount for being a member of Defender2. 1982 88" 2.25 diesel
Post #775032 26th May 2019 11:44am
Zed
Thanks for that. I had mentioned it to another site sponsor but they didn't know. I'll give AF a shout.
Post #775045 26th May 2019 3:28pm
