Home > Maintenance & Modifications > Headlamp maintenance |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1392 |
Hi Pete,
Regarding replacement, park it facing a wall or the garage door, a good few metres back. Note where the beam strikes or mark the positions, for dipped and high beam. Fit the new headlight and adjust it to the same spot(s). So long as the original was adjusted properly the new one should be ok. The cheapest option without upgrade will be replacing just the one broken lamp. Where to buy? Support your local independent LR specialist. They're having a tough time just now, no new Defenders coming along and the farmers have moved to Ford Rangers or similar. Get to know them, then when you need parts or advice they will hopefully recognise you as a repeat customer. I'm looking for a new independent specialist, the one I've used for the past 10 years has recently ceased trading. |
2nd Jun 2018 10:40pm |
They're just standard Wipac quadoptic H4 Lamps.
You can get them from just about any classic car specialist, they fit all sorts. The Defender can use the ones from the Mini's etc with the side light built in, as you can just leave it unoccupied. https://www.lrisolutions.co.uk/pair-headli...0-110.html LRI have some here with stainless bezels - the stainless bezels are a worthwhile upgrade, as the standard ones rot out. |
2nd Jun 2018 10:41pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Forget about replacing with a standard unit, fit a pair of Wipac Crystal units with Phillips X-treme bulbs - you will be absolutely amazed at the difference they make to driving at night! Headlamps about £35-40, bulbs another £15-20 well worth the investment
As already said, park in front of a wall & mark your beam position then adjust new units to the same marks once fitted. Last edited by VVS210 on 3rd Jun 2018 9:47am. Edited 1 time in total |
3rd Jun 2018 7:42am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 729 |
You will almost certainly need new adjustment screws and bezel fixings. The s/s bezels and fixings can be obtained from site sponsor "Leeds".
The non stainless headlamp fixing kit is part number STC1614. This includes the two adjusting screws. |
3rd Jun 2018 9:36am |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 502 |
Definitely recommend the above, and the Boomslang upgraded loom while you're there. It'll make an unbelievable difference! Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
3rd Jun 2018 9:43am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20264 |
As above, and get the original fixings out and replace with SS ASAP before they just up.
Otherwise you might end up needing new headlamp bowls as well if the fixings break off. If you don't want to do headlight levelling just book it into Halfords or similar for it won't cost you very much at all. |
3rd Jun 2018 11:12am |
When I put new headlamps in my mums Citroen, I just took it to Kwikfit and asked them, I think they charged a tenner or something. |
3rd Jun 2018 9:42pm |
PeteO Member Since: 17 Oct 2016 Location: Newmarket Posts: 11 |
First of all, apologies for the tardiness of my appreciation for all your helpful comments.
I managed to get the job done as advised by your good selves. Alas, I then involuntarily went out of commission for a while, and my LR was involved in a deer collision. So, I’m back on the case, and now would like to tap the wealth of experience & knowledge you guys have. I was given a set of cheapo LED headlights that incorporate DRLs, so I have the standard 3-pin connection, plus another single wire with a female spade connector for wiring the dRLs. The Headlights work well (using the advice you all gave me to ensure the lights point in the right direction), but what do I do with the DRL wire ? Ideally, I’d like them on all the time, until I turn on the sidelights/headlights. I’ve had a look on the various forum sites, but none seem to exactly match my needs. I’m hoping the solution is within my currently limited ability, but if necessary will go to Halfords/whatever. Thank you |
13th May 2019 10:32pm |
Buy a DRL controller off ebay & follow the instructions is probably thte quickest & easiest
14th May 2019 5:48am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
If you need to buy a DRL controller off the likes of eBay to get a set of LED headlights to work correctly then the chances are extremely high that the headlights are illegal.
Brendan |
14th May 2019 6:12am |
Light function code of LED headlights with DRL incorporated will have HCR and RL marked on lens
Brendan |
14th May 2019 6:13am |
Thanks leeds - didn't know that about the HCR/RL stuff.
I checked & you're quite right - nowhere to be seen on the pair I have, but as I said, they're cheapos. That said, the main/dip functions work OK. Its just how/where to connect up the DRL wire. |
14th May 2019 9:08am |
Without the correct approval markings they are not road legal. Try telling your insurance company that you have done an illegal modification to your vehicle.
Brendan |
14th May 2019 5:43pm |
Thank you leeds, you raise a very good point.
And you've expanded my knowledge as well ! Clearly I'm going to have to replace the cheapo LED headlights with proper normal ones, perhaps with an improved normal bulb. I'm very much obliged to you and all the other contributors. |
14th May 2019 7:50pm |
