Home > Maintenance & Modifications > Headlamp maintenance
PeteO
England 1994 Defender 110 300 Tdi CSW Rioja Red
Hi
A virgin poster here !
My 300tdi CSW suffered a stone chip that punctured a hole in the headlamp glass.
Any advice on replacement/relatively cheap upgrade ?? e.g. Part numbers / sourcing websites
I'll be doing the work myself (retired, so am supposed to have lots of time on my hands, but doesn't seem to have worked out that way).
Thanks in hope
Post #710520 2nd Jun 2018 9:57pm
DSC-off
Hi Pete,
Regarding replacement, park it facing a wall or the garage door, a good few metres back. Note where the beam strikes or mark the positions, for dipped and high beam. Fit the new headlight and adjust it to the same spot(s). So long as the original was adjusted properly the new one should be ok.
The cheapest option without upgrade will be replacing just the one broken lamp.
Where to buy? Support your local independent LR specialist. They're having a tough time just now, no new Defenders coming along and the farmers have moved to Ford Rangers or similar. Get to know them, then when you need parts or advice they will hopefully recognise you as a repeat customer.
I'm looking for a new independent specialist, the one I've used for the past 10 years has recently ceased trading. Sad
Post #710528 2nd Jun 2018 10:40pm
zsd-puma
They're just standard Wipac quadoptic H4 Lamps.
You can get them from just about any classic car specialist, they fit all sorts. The Defender can use the ones from the Mini's etc with the side light built in, as you can just leave it unoccupied.
https://www.lrisolutions.co.uk/pair-headli...0-110.html
LRI have some here with stainless bezels - the stainless bezels are a worthwhile upgrade, as the standard ones rot out.
Post #710529 2nd Jun 2018 10:41pm
VVS210
Forget about replacing with a standard unit, fit a pair of Wipac Crystal units with Phillips X-treme bulbs - you will be absolutely amazed at the difference they make to driving at night! Headlamps about £35-40, bulbs another £15-20 well worth the investment Thumbs Up
As already said, park in front of a wall & mark your beam position then adjust new units to the same marks once fitted.
Post #710554 3rd Jun 2018 7:42am
Balvaig
You will almost certainly need new adjustment screws and bezel fixings. The s/s bezels and fixings can be obtained from site sponsor "Leeds".
The non stainless headlamp fixing kit is part number STC1614. This includes the two adjusting screws.
Post #710572 3rd Jun 2018 9:36am
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
VVS210 wrote:
Forget about replacing with a standard unit, fit a pair of Wipac Crystal units with Phillips X-treme bulbs - ypu will be absolutely amazed at the difference they make to driving at night! Headlamps about £35-40, bulbs another £15-20 well worth the investment Thumbs Up
Definitely recommend the above, and the Boomslang upgraded loom while you're there. It'll make an unbelievable difference! Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #710573 3rd Jun 2018 9:43am
As above, and get the original fixings out and replace with SS ASAP before they just up.
Otherwise you might end up needing new headlamp bowls as well if the fixings break off.
If you don't want to do headlight levelling just book it into Halfords or similar for it won't cost you very much at all. Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #710578 3rd Jun 2018 11:12am
zsd-puma
When I put new headlamps in my mums Citroen, I just took it to Kwikfit and asked them, I think they charged a tenner or something.
Post #710658 3rd Jun 2018 9:42pm
PeteO
First of all, apologies for the tardiness of my appreciation for all your helpful comments.
I managed to get the job done as advised by your good selves.
Alas, I then involuntarily went out of commission for a while, and my LR was involved in a deer collision. Big Cry
So, I’m back on the case, and now would like to tap the wealth of experience & knowledge you guys have.
I was given a set of cheapo LED headlights that incorporate DRLs, so I have the standard 3-pin connection, plus another single wire with a female spade connector for wiring the dRLs.
The Headlights work well (using the advice you all gave me to ensure the lights point in the right direction), but what do I do with the DRL wire ?
Ideally, I’d like them on all the time, until I turn on the sidelights/headlights.
I’ve had a look on the various forum sites, but none seem to exactly match my needs.
I’m hoping the solution is within my currently limited ability, but if necessary will go to Halfords/whatever.
Thank you
Post #773060 13th May 2019 10:32pm
VVS210
Buy a DRL controller off ebay & follow the instructions is probably thte quickest & easiest Thumbs Up
Post #773066 14th May 2019 5:48am
leeds
If you need to buy a DRL controller off the likes of eBay to get a set of LED headlights to work correctly then the chances are extremely high that the headlights are illegal.
Brendan
Post #773071 14th May 2019 6:12am
leeds
Light function code of LED headlights with DRL incorporated will have HCR and RL marked on lens
Brendan
Post #773072 14th May 2019 6:13am
PeteO
Thanks leeds - didn't know that about the HCR/RL stuff.
I checked & you're quite right - nowhere to be seen on the pair I have, but as I said, they're cheapos.
That said, the main/dip functions work OK.
Its just how/where to connect up the DRL wire.
Post #773092 14th May 2019 9:08am
leeds
Without the correct approval markings they are not road legal. Try telling your insurance company that you have done an illegal modification to your vehicle.
Brendan
Post #773145 14th May 2019 5:43pm
PeteO
Thank you leeds, you raise a very good point.
And you've expanded my knowledge as well !
Clearly I'm going to have to replace the cheapo LED headlights with proper normal ones, perhaps with an improved normal bulb.
I'm very much obliged to you and all the other contributors.
Post #773171 14th May 2019 7:50pm
