Home > Maintenance & Modifications > Help with dog guard fitting
bear100
Hi
Ive had my dog guard in the garage for about 4 years and today I’ve got around to fitting it well trying too!
The top brackets have got me stumped I’ve fitted them but they are way too long see pictures
I can’t see where I’ve gone wrong either,
10 plate 110 utility
 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #772769 12th May 2019 2:21pm
Yatesy
United Kingdom 2011 Defender 90 Puma 2.4 HT Zambezi Silver
Mines a 90 so the brackets are slightly different but the guard leans back at an angle whereas you have yours upright.
Post #772776 12th May 2019 2:50pm
bear100
Hi Yatsey
Yeah that’s a different bracket to mine, the bottom of my guard is angled back but the top sits straight the bottom brackets all went together without a hitch so thinking I may have the wrong uppers! 2016 Range Rover Autobiography 4.4 TDV8
Post #772793 12th May 2019 4:04pm
discomog
When I bought my 90 new, the dealer fitted a genuine Land Rover dog/cargo guard. I seemed to remember that the brackets marked LH and RH were fitted with the LR on the right hand side and RH on the left hand side. I'm assuming that the brackets had the labels switched when new. I've just gone out to the garage to check and they are definitely fitted the wrong way according to the labelling. Maybe this is your problem - just a thought! Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #772808 12th May 2019 4:51pm
seriesonenut
Just looked at mine. I recall it was a nightmare to fit. I assembled it all loosely and after a fight it went in.Excuse the dangerous (ikea rats) cargo! Rolling with laughter
lh guard by Richard Holmes, on Flickr
rh guard by Richard Holmes, on Flickr 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #772809 12th May 2019 5:04pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Dog Guard
I removed a guard a couple of days ago from a 2010 110. I am certain those brackets were one bolt further forward.
Mine had a 45 degree angle bracket from the door post to the roof join and the back bolt was used for both the guard bracket and the angle support.
Is it possible to move your bracket one bolt further forward?
Post #772811 12th May 2019 5:22pm
jrw
United Kingdom 2014 Defender 110 Puma 2.2 USW Loire Blue
I fitted one last year and it was a right pain to do. In the end I slackened everything off (bottom section as well) and managed (with a bit of brute force) to get those brackets to fit - it was tough going though!
Have removed the upper section a couple of times to transport long items and it’s still a fight to get those two sides to marry up and tighten Rolling Eyes 2014 110 XS Utility
2017 D5
2012 FFRR TDV8
Post #772846 12th May 2019 7:50pm
Sulisuli
I don’t think anyone has found fitting these dog guards easy ever. Thumbs Up your not alone, good luck hope you get it sorted. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #772849 12th May 2019 8:06pm
seriesonenut
And I thought it was just me Laughing Flipping hard work to get everything lined up. Like mentioned above a loose fit then brute force. I used a pick axe handle as a lever to 'lift' the guard whist a second pair of hands managed to tighten everything up. I only managed to get one of the two bolts in the top bracket fitted but it seems to be ok. 1984 One-Ten CSW
2010 XS USW (sold)
Post #772854 12th May 2019 8:20pm
bear100
They are tricky to fit for sure!
Well I've done it Very Happy in my eyes the top section should be horizontal, i moved the bracket back one bolt hole thanks seriesonenut and as a result could only fit one bolt back in (for now until i drill and make one) the top section does lean toward the rear door but nowhere as bad if the brackets were in the position as stated in the instructions though.
thanks for all your help Thumbs Up Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #772979 13th May 2019 6:35pm
