Home > Maintenance & Modifications > Working with Waxoyl? |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I would get some on yes. Steve.
23rd Jun 2011 10:34am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 |
Put the tin of waxoyl in a bucket of hot water and it'll be easier to apply
23rd Jun 2011 11:41am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I just had mine done too. So when it came to bolting all the bits and pieces back onto the underside I purchased a couple of aerosol cans of waxoyl, left them in the sink submerged in hot water for 30 mins and it sprayed beautifully onto all the new bolts, nuts etc with no splatter or blocked nozzles
I also purchased the spray kit but for small touch up jobs the aerosol cans are brill apart from the price, £8 odds a can from halfrauds |
23rd Jun 2011 12:56pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
If I had my frame waxoiled and wanted it all removed is that impossible?
23rd Jun 2011 2:19pm |
What would be the point of having it done in the first place? Oh well, a hot enough steam clean and solvent / detergent wash ought to shift a lot of ordinary Waxoyl from external surfaces but you'll not get it out of the inside of the chassis frame etc. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
23rd Jun 2011 3:02pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
where's Zagato , our local waxoiling expert
23rd Jun 2011 3:12pm |
Yeah right Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
23rd Jun 2011 3:27pm |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 |
:lol: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2005 TD5 90 Hard Top Beer 'n Sex 'n Chips 'n Gravy |
23rd Jun 2011 3:32pm |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 350 |
Eutek - I would go and see Michael and I bet you he will slap you some on for free and also at the same time check the work he did last year. Proud owner 110 Utility XS
Ex RR Sport HST V8 Ex Td5 90 |
2nd Jul 2011 8:31am |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
Probably waxoilling as we speak Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
2nd Jul 2011 9:31am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5045 |
Removing waxoyl can be done easily if you want to (why would you) get a 5l tub of WD40 spray the chassis and then blast off.
In terms of adding removing bits - i would keep (and do) a selection of waxoyl prodcuts - brush on, aresol and spray. Every time i remove something on the disco or in fact the 90 when i had it, i would recoat and apply where there never had been any. But one thing i would say - no matter how hard you try and we no Zag has played a little with waxoyl - a land rover will rust and will corrode if you use it! The more you protect the known points, the more another area will. I always thought the common points are the path of least resistance and actually the more difficult areas then will rust. I would still waxoyl it though! Mike |
2nd Jul 2011 9:33am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Hi Eutek, I haven't got a Doctorate in Waxoyl but as others have said, yes you will need to reapply Waxoyl or similar to any newly exposed areas to keep them rust free and it's good practice to put a smear of copper grease on bolt threads so they can be easily removed in the future if necessary, especially underside fasteners |
2nd Jul 2011 3:02pm |
