Home > Puma (Tdci) > Oil Leak
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Oil Leak
I've developed an oil leak from the circled red area by the transfer box on my 2010 TDCI 110.
I cleaned off all the old oil using brake cleaner and took it for a quick spin.
Not sure if it is leaking down from where the transfer extension case meets the transfer box as I always thought the transfer box was dry???? Or is it leaking from the inspection cover and being blown upwards?
Any ideas and suggested fixes?
Post #772453 10th May 2019 12:55pm
Retroanaconda
Probably transfer box intermediate shaft seal. A poor design sees the shaft wearing the housing oval and then the o ring no longer seals.
Fix is a steel sleeve fitted to the box housing and requires stripping the box to do it. Or just live with it, as it’s usually a pretty slow leak.
Post #772458 10th May 2019 1:09pm
boxoftricks
Thanks, it is leaking a few drops after each run is my guess. Is the steel shaft a specialist machine shop job or can a standard garage fix?
Post #772459 10th May 2019 1:18pm
MK
Another less bad scenario is that the oil is coming through the female thread of such bolt. I would give it a try with a bit of teflon. Puma 110" SW
Post #772467 10th May 2019 1:53pm
Machine shop job, or Ashcroft Transmissions.
Post #772533 10th May 2019 7:12pm
