Home > Puma (Tdci) > Oil Leak |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2641 |
Probably transfer box intermediate shaft seal. A poor design sees the shaft wearing the housing oval and then the o ring no longer seals.
Fix is a steel sleeve fitted to the box housing and requires stripping the box to do it. Or just live with it, as it’s usually a pretty slow leak. |
10th May 2019 1:09pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Thanks, it is leaking a few drops after each run is my guess. Is the steel shaft a specialist machine shop job or can a standard garage fix?
10th May 2019 1:18pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Another less bad scenario is that the oil is coming through the female thread of such bolt. I would give it a try with a bit of teflon. Puma 110" SW
10th May 2019 1:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17367 |
Machine shop job, or Ashcroft Transmissions. |
10th May 2019 7:12pm |
