Home > Maintenance & Modifications > Water leak.
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
Water leak.
We had our first lot of rain since we took delivery of our 90. It looks like I have a leak which is coming through the seal where the hard top sides meet the tub. It looks like the seal is pushed in 2 or 3mm in one place and the seal is wet on the other side in this place. How big a job is it to lift the sides and replace the seal or does anybody have any other ideas to fix it? Thanks
Post #772095 8th May 2019 12:12pm
Co1
It looks like the sides aren’t clamped down hard enough, check that the bolts aren’t slack first.
Post #772103 8th May 2019 12:53pm
sgreenham
Only the middle one was slack but the ones either side were all pretty tight. There's only the one in the back corner and the other near the driver's door isn't there?
I tightened this up but it doesn't look strong enough to make a huge difference
These were both tight...
Looks like I could use this are to fix it stronger but not sure if I should...
Post #772109 8th May 2019 1:38pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Welcome to the world of defender ownership. Typically most leak at the front into the footwells so hopefully yours will be a quick fix.
Tommo
Post #772118 8th May 2019 2:07pm
landy andy
I seal mine with tiger seal or sikaflex
Post #772182 8th May 2019 7:21pm
sgreenham
This is what I've chosen to do as well. I've run some sikaflex down there, hopefully that does the job.
Post #772220 9th May 2019 6:24am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
I've tiger sealed mine and every other joint I can access....
Post #772232 9th May 2019 8:13am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I did my mine with Sikaflex about 5 years ago along with the roof joints and its still sealed. To make a neat job I used masking tape (the blue of green stuff which comes off easier ) about a 1/16" away from the edge run a medium bead of sealer along the whole length and using a "thumb" which you can buy cheap ran that along the whole seam in one go then pull off the tape before the sealer has time to start to cure. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #772241 9th May 2019 8:55am
turnah
United Kingdom 2005 Defender 90 Td5 HT Belize Green
I've also used black tiger seal all the way around. I ran my (latex gloved) thumb round with a little white spirit to get a nice smooth finish. Not had any issues since and i think it looks quite lovely.
Here's a picture
Post #772278 9th May 2019 1:19pm
