![]() | Home > Maintenance & Modifications > Backlash |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1121 ![]() ![]() ![]() |
I have some backlash on my 300tdi, which is getting worse.
Rear diff, gearbox recon, cv joints front new, props all good. How much movement should there be up and down, on the transfer box flange where the front prop fits?. Many thanks |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
Up and down, none at all.
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
There shouldn't be any but i have always found there is a small amount detectable if you lay underneath and give it a shake. From memory the front output bearing isnt a press fit into the housing but is circliped in, a fractional movement of this feels worse than it is.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
many thanks for all the help , there is a small oil leek from the front flange .
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Another issue there is although it is not so likely to suffer as much water ingress on the front. If oil can leak out moisture can get in. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
