Home > Puma (Tdci) > serious engine probs....broken down!! |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
I've used millers before, every tank for a couple or three months and had no issues at all - for that matter, no noticeable benefits either, but you should be able to rule it out as a potential issue...
19th Jun 2011 9:42pm |
Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431 |
I would keep quite, they will be looking for any excuse ....
Jack |
19th Jun 2011 9:45pm |
nicknick Member Since: 28 Feb 2011 Location: halifax Posts: 30 |
thanks bigfog, i got the millers stuff as a free sample so i thought i may as well try it but you have confirmed my thoughts, i didnt think i would notice any diffrence.
19th Jun 2011 9:47pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I don't think pressure washing the underneath would cause a great deal of water to enter the fuel tank even if you managed to find the tank breather and hit it square on and left the lance there for a minute or two, but could all that mud you removed have restricted/blocked the tank breather? I use forte diesel treatment with no issues and I'm sure millers would be the same. The symptoms you describe could be the EGR valve stuck open but that should throw up a DTC but a restricted tank breather wouldn't . It could also be the High pressure fuel rail (really loud diesel knock), fuel rail regulator or injectors but these all throw up DTC's. Have you been wading recently? Did the tech check the Turbo modulator, EGR, MAF plugs and the injector harness?
20th Jun 2011 7:58am |
thanks for the useful advice lorryman, i got the defender back today all ok, guess what caused it ? some complete c**k
put £30 worth of unleaded in it so £400 poorer and all is well. er indoors is going mental , no off roading for me this weekend then. thanks everyone for their replies and please try not to wet yourselves laughing at me! p.s 13 vehicles in my fleet and not one of them is petrol, how the hell did i manage it?? |
22nd Jun 2011 6:08pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Done it 3 times now with my SAAB Bleedin job to get it sorted
22nd Jun 2011 6:18pm |
for owning up, I'd have blamed the missus
Mind you, only because she drives a petrol car |
22nd Jun 2011 6:19pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 |
Look on the bright side-all is well now. Bet you get some stick from the Mrs. every time you stop to fill up. I can just hear it now-"Make sure it is diesel, Dear."Bet that after hearing that five or six times you will be thanking Land Rover for putting the wheelbrace in such a secluded spot. Some good has come out of this.You learned a lesson and you will never make that mistake again. Most importantly-we all got a good laugh 1982 88" 2.25 diesel
22nd Jun 2011 7:19pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Everyone does it once (or more). I did it in an escort van, temping at university years ago. It went down like a ton of sh*t with the boss.
I know diesel fuel pump nozzles are fatter than petrol ones and therefore don't fit in petrol fuel tanks, but as for the other way round, there's an invention worth a few quid. Being a father of two under 4's, I'm thinking red triangular nozzles for diesel and green square nozzles for petrol |
22nd Jun 2011 7:27pm |
Barry Member Since: 26 Apr 2011 Location: North East Posts: 137 |
I take it there have been no further instances other than yourself , it wouldnt be the first time the station has gotten the tanks/pumps mixed up. 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
22nd Jun 2011 7:41pm |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 |
you may well experience problems later down the line, the TDCI engine does`nt like petrol through it, my mate gets quite a few through his garage and says that if people notice straight away that they have filled up with petrol and stop the engine they normally get away with it, but if they drive any distance and especially if they drive till the engine stops they will have trouble immediately or not long after. problems are usually high pressure pumps and injectors, i did the same with my transit but luckily twigged after 200 yards and fingers crossed its been ok. i hope you get away with it as i know pump and injectors are not cheap. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
23rd Jun 2011 5:41pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
Indeed, since the pumps rely on the lubricity of the diesel for lubrication. I would recommend you start running your landy with 2-stroke oil for added lubricity just in case. JASO-FB or FC spec at 1:200 ratio, add it before you put diesel in. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th Jun 2011 7:18am |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 222 |
Already exists and LR are fitting the device to the Disco4s. Haven't quite worked out how it works yet but if activated it completely blocks the filler and will just make the petrol pour back out! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
24th Jun 2011 8:53am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
Yes my range rover has one - it stops missfueling by locking off the tank the moment you put the wrong nozzle in - you then have to get the tool out of the boot Mike |
24th Jun 2011 1:04pm |
