Home > Expedition & Overland > Whats the best tent for an expedition roof rack(VPLDR0160)?
Juanplatano
Switzerland 2012 Defender 110 Puma 2.4 Black LE Java Black
I was thinking of getting a Maggiolina or an airtent.. any recommendations?
Post #767395 7th Apr 2019 1:46pm
I'd suggest that the best tent for that rack is one that you take off and set up on the ground. Darren
Post #767408 7th Apr 2019 2:49pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
My goodness!! That's beautiful! is that a new paint job, looks very clean!!
PS I don't think you will get a roof tent on that... I had to take the side bars off my roof rack to get the tent on...
Unless you make feet for the rtt to sit on??? Or place a standard set of roof bars over the roof rack?? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #767410 7th Apr 2019 2:57pm
j17
I’ve chopped my rack to fit a roof tent
I’m going to find some brackets to join the part I cut off back on for when tent is not mounted
Think that’s the best way to use genuine rack for a roof tent
Post #769557 22nd Apr 2019 8:54am
Adam17
Looks pukka chap. Regards
Adam
Loving The Duchess
Post #771331 3rd May 2019 11:12am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
We've got an air tent. I can set up the 6 man tent in 15 min upon arrival at a campsite solo. Three main arches are inflated, all interior dividers are already in place. Slide one pole in for the porch and all done. The blackout bedrooms are amazing, no more bright sunshine waking us or the kids up at silly o'clock
https://www.coleman.eu/UK/p-26802-valdes-6-xl-air-tent.aspx
Only downside is it is a big old lump when not set up.
Post #771340 3rd May 2019 11:27am
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Watching, I’m also wondering if a maggi would work without butchering the rack.
Post #771824 6th May 2019 10:07pm
Gilloverland
TBH you'd probably be better selling that rack and looking for something more like a front runner / flat dog type rack for a roof tent.
Post #771827 6th May 2019 10:26pm
Al_The_Pal
Bit more research last night shows the small Maggi will fit, measurements show the height of the bottom case is 80mm and the height of the top rail of the expedition rack is 110mm... looking at how they work, I don’t see this being a show stopper
http://www.autohome-official.com/en/produc...li-tecnici
Also the tent box has a similar setup and appears cheaper
https://www.tent-box.com/uk/
At present I don’t see why these wouldn’t work given that the ladder will be able to be used against the rack and not the case of the roof tent
Post #771839 7th May 2019 7:24am
landy andy
With the small Maggi’s you always have to put the ladder against the rack anyway as they are too narrow, so tent is set inward. Maggi’s are fantastic tents. I wouldn’t have anything else, if I went back to tents.
Post #771840 7th May 2019 7:54am
Al_The_Pal
Loving that setup, and the rack is very similar to expedition one.
Post #771884 7th May 2019 12:38pm
leeds
We have fitted a small maggiolina tent to that sort of rack - fiddly but worked.
Regards
Barbara
Post #771912 7th May 2019 2:42pm
Al_The_Pal
Bit more research shows the maggi will work with the genuine rack... my mind is made up 😀
Post #772718 12th May 2019 7:19am
landy andy
Good in all weather.
Post #772719 12th May 2019 7:47am
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
if you want a hard shell go maggiolina - -doesn't flap about in high wind and therefore quiet inside. the wind up version is probably more robust than the airtop gas struts. (I have a maggiolina)
if you want more rack space then go gordigear --superbly made and all parts replaceable (see their video) (I had a hannibal, then had a large gordigear explorer plus, and will be buying another (smaller) gordigear.
you may need to loose some of your rack side rails though! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #775171 27th May 2019 10:40am
