Home > Maintenance & Modifications > Rear quarter light grills
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
I’m about to install these quarter light grills. I was expecting some that just bolted on top, but these appear to need the window removed and sandwiched between the two parts of the grill. (LRD security)
Before I take out the window, are the 10 fixing bolts designed to sit in the existing window space, or will I need to drill 10 holes to take them?
Post #771703 6th May 2019 9:45am
Having read the blurb on their website, it specifically says they were designed so that there is no need to drill the body. It looks like the bolts go through the space that would usually be taken up by the rubber seal, which these parts replace completely. Darren
Post #771708 6th May 2019 11:11am
geostrategist
Yet again I’ve answered my own question:
Yes, you do need to remove the window, and yes the bolts fit in the gap - no drilling. Not as easy removing them as it looks compared the videos of guys breaking in via the back, but I didn’t want to damage anything. Quote straightforward, if a little fiddly to fix in once the window is out. However, you do need to remove the side trim (if fitted, mine’s a CSW) to secure the three outboard nuts. That’s a work in progress at the moment!
Post #771710 6th May 2019 11:23am
Zed
Interested to see how you get on. I had asked Will for a photo of it fitted with all trim in place but still waiting.
Post #771711 6th May 2019 11:29am
geostrategist
The top middle and inboard nuts are easy enough to tighten, however the outboard 3 are covered by the trim. after a significant amount of swearing etc, i managed to loosen the side trim, and get 2 nuts secured (I didnt have the room to do the washer as well, as I needed a third hand to secure it.) the 3rd (lowest) nut on that side was beyond me, as it is obscured by the seat-belt inertia reel mechanism.
Whilst the guards look good, and should do the job, I wouldn't recommend for a station wagon, unless all the trim is coming out.
Post #771720 6th May 2019 12:11pm
geostrategist
Post #771724 6th May 2019 12:14pm
geostrategist
Finally with the trim attached. It is fouled a bit by one of the line of nuts.
Post #771732 6th May 2019 1:11pm
AMBxx
Has anyone found a better way to reattach the rear trim? I have guards on the inside of the windows that foul the trim slightly. Means the trim doesn't quite fit and comes off too easily.
I was thinking of using rivnuts instead of the little clips - anyone else tried?
Post #771851 7th May 2019 7:53am
Not yet but it's my list of things to do. Those spring clips drive me mad. It'll need a spacer making to fit between the trim and the metal door frame to replace the existing spring clip and it's mount. I have in mind some 6mm nylon, cut and drilled to suit, which can be glued to the back of the trim. Darren
Post #771879 7th May 2019 11:16am
geostrategist
I’ve finally got round to installing the other side. This is the amount of trim that I needed to remove, and the inertia reel
Post #776072 3rd Jun 2019 4:32pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Wow I can’t believe the difference in amount of trim you have to remove when on a Td5 the panel just pulls off! I guess that’s all because and the seat belt mounting etc.
Thanks for posting the pictures as I’m think of a set of guards myself Thumbs Up
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #776131 4th Jun 2019 5:50am
