Home > Puma (Tdci) > Puma Engine Mounts |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Question !! Are the 2012/2014 MY engine mounts fluid filled ?? I have a clear reddish hydraulic fluid like fluid in the area of the mount, no idea what else it could be. Its not anti-freeze dose not smell or feel right. Its not engine oil so even me a Land Rover expert is scratching my head a bit. Internet and searches on here showing nothing of interest.
Anyone got any info please. I was towing heavy trailers up steep hills last week it is entirely likely the engine mount could have failed. If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
5th May 2019 5:16pm |
Good shout but not dark enough red, it is a very light oil tinged red, i have not changed my pas fluid for 100thou so that would be dirty also.
The puddle in the drive has also evaporated leaving a stain, deffo not anti freeze does not smell right and has an oily feel, If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
5th May 2019 6:06pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
I asked the same question some time back. Still donโt know the answer
https://www.defender2.net/forum/topic50097.html > 110 XS Double Cab |
5th May 2019 6:11pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
Bear in mind the OAT coolant does go dark in colour when it dries or has been very hot.
I noticed this when I had a coolant leak when it dried on the water pump when I had issues there. It may not be that of course, but I did notice this as I thought at the time hmmm. I thought it was orange. It is when it goes in but it isn't when it dries out or has been very hot. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
5th May 2019 6:33pm |
Just out of interest to narrow down the area , which side of the engine and is front or rear. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th May 2019 4:01pm |
Found this but it's not a particularly reliable source - "hydraulic engine mount"
https://webcache.googleusercontent.com/sea...&gl=uk > 110 XS Double Cab Last edited by hank on 7th May 2019 5:23am. Edited 1 time in total |
6th May 2019 5:33pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 |
Funny you say that; my Td5 both the engine mounts have traces of a fluid coming out of them and staining the (galvanized) chassis (thus its easy to see) Td5 & puma use the same mount. I know a lot of the Merc mounts are properly oil filled, but not sure about LR... there must be something inside them that a few of us are experiencing whatever it is "leaking" out. |
6th May 2019 7:06pm |
N/S engine mount, fluid leaking to the rear of it and running down the chassis. I have double treble checked al pipes and pums ect above it all dry. If everything is under control you are not going fast enough.
7th May 2019 1:00pm |
I had the same thing happen about 4 or 5 weeks ago.
Check the oil filter assembly if its the same as the 2.4 filter assembly it will have a cooler on it, check round the rubber pipe's that is were mine was leaking from the spigot that is bolted to oil filter , its the one faces the side of the engine. The spigot fractured and was leaking, I mistook what was coming out as hydraulic fluid it was such a dark colour . A local indie that did the work said the thermostat that is part of the spigot had also failed. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
7th May 2019 6:29pm |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 |
The Oil filter of the early 2.2 engines is the same as for 2.4 engine. Later models use a spin-on filter, whereas 2.4 and early 2.2 engines use a paper filter.
8th May 2019 8:23pm |
Found my leak at long last and only as a result of a neigh on impossible to change turbo hose failing. The hose in question is the 90 deg one under the inlet manifold but whist in there with a lot of the water hoses removed i found the plastic rear outputs from the water pump has an "O" ring that fails and leaks under pressure, trickles down the metal inlet pipe and onto the engine mount. If everything is under control you are not going fast enough.
10th Aug 2019 9:58am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
good find. and I was wondering if it could possibly be the a/c. |
10th Aug 2019 10:05am |
