Home > Tdi > Windscreen wiper removal |
AndrewFoxPitt Member Since: 30 Apr 2019 Location: London Posts: 5 |
Hello everybody
Thanks for your advice re the footwell rust. I've got another problem I'm currently working on - the windscreen wipers are moving very slowly (they go back into position) so I'm currently stripping the system down to the motors as detailed here; https://www.firstfour.co.uk/news/land-rove...air-guide/ I've come across quite a fiddly problem though - how on earth do you remove these parts of the windscreen wipers (the large parts on the end)? Thanks Click image to enlarge Click image to enlarge |
1st May 2019 4:56pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
Circled is a grub screw. If you're lucky it'll undo.
Choose the Allen key carefully as it is easy to strip. Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st May 2019 5:23pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 |
Depending if any sort of anti-seize was used when they were last fitted, they could be really hard to get off, and there is the risk of damaging stuff round about.
I'd suggest seeing if you could find a small puller to use on this. Obviously you'd need something (bolt with head cut off?) to fit down inside the end of the fitting, so that it was bearing on the wheelbox shaft. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
1st May 2019 6:36pm |
Mariner Member Since: 03 Oct 2017 Location: Arklow Posts: 127 |
I had the same problem with mine and they still wouldn't budge after soaking in WD40 but they came away easily with the use of a small 2 legged puller.
2nd May 2019 12:20am |
I'll just cut them off with a cutting disc and replace the boxes and cable, around a £50 expense.
Thanks all for your help! |
2nd May 2019 11:07am |
Consider doing the double screen washer mod while you have everything apart :
2nd May 2019 7:39pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20580 |
A small puller is only about £12 - £16 designed for the job. Be very careful of your paint and glass if cutting off for many reasons. KEEP CALM AND Drill ON
2nd May 2019 8:47pm |
Ok guys, a little update.
I replaced the boxes + checked the original cable (all fine), put it all back on and...very little difference. I also noticed that selecting a faster wiper speed does nothing, just the same lethargic speed as the slower setting. I've looked at replacing the park motor switch but that seems to only affect where the wipers stop? The brushes have been mentioned to me as a good place to start, what do you think? Thanks again for your help! |
7th May 2019 12:02pm |
OJ Member Since: 23 Nov 2018 Location: North of Edinburgh Posts: 121 |
Assuming the wiring and switch is ok its most likely the brushes, had a similar problem and replaced the brush assembly and they’re working fine now.
Look on eBay at item eBay Item No. 233187658787 Cheers OJ |
11th May 2019 6:46pm |
