Home > Tdi > Windscreen wiper removal
AndrewFoxPitt
Hello everybody
Thanks for your advice re the footwell rust.
I've got another problem I'm currently working on - the windscreen wipers are moving very slowly (they go back into position) so I'm currently stripping the system down to the motors as detailed here; https://www.firstfour.co.uk/news/land-rove...air-guide/
I've come across quite a fiddly problem though - how on earth do you remove these parts of the windscreen wipers (the large parts on the end)?
Thanks
Post #771072 1st May 2019 4:56pm
Martin
Site Admin
Circled is a grub screw. If you're lucky it'll undo.
Choose the Allen key carefully as it is easy to strip.
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #771077 1st May 2019 5:23pm
donmacn
Depending if any sort of anti-seize was used when they were last fitted, they could be really hard to get off, and there is the risk of damaging stuff round about.
I'd suggest seeing if you could find a small puller to use on this. Obviously you'd need something (bolt with head cut off?) to fit down inside the end of the fitting, so that it was bearing on the wheelbox shaft. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #771092 1st May 2019 6:36pm
Bps
I’ve just tightened mine up and it’s a 3/32 Allen key, not metric. Very easy to strip out the head with the wrong size. If you are replacing the wiper wheel boxes ( use genuine as you don’t want to do it to often) it’s easier just to cut of the end altogether before removing the old. Just make sure you protect the paint work and screen
Post #771093 1st May 2019 6:47pm
Mariner
Ireland
I had the same problem with mine and they still wouldn't budge after soaking in WD40 but they came away easily with the use of a small 2 legged puller.
Post #771146 2nd May 2019 12:20am
AndrewFoxPitt
I'll just cut them off with a cutting disc and replace the boxes and cable, around a £50 expense.
Thanks all for your help!
Post #771200 2nd May 2019 11:07am
Mariner
Ireland
Consider doing the double screen washer mod while you have everything apart :
Post #771276 2nd May 2019 7:39pm
A small puller is only about £12 - £16 designed for the job. Be very careful of your paint and glass if cutting off for many reasons. TheThunder Rolls🇬🇧🇺🇸
Post #771289 2nd May 2019 8:47pm
AndrewFoxPitt
Ok guys, a little update.
I replaced the boxes + checked the original cable (all fine), put it all back on and...very little difference.
I also noticed that selecting a faster wiper speed does nothing, just the same lethargic speed as the slower setting.
I've looked at replacing the park motor switch but that seems to only affect where the wipers stop?
The brushes have been mentioned to me as a good place to start, what do you think?
Thanks again for your help!
Post #771891 7th May 2019 12:02pm
OJ
Scotland 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Assuming the wiring and switch is ok its most likely the brushes, had a similar problem and replaced the brush assembly and they’re working fine now.
Look on eBay at item eBay Item No. 233187658787
OJ
Post #772656 11th May 2019 6:46pm
