Home > Puma (Tdci) > How to check level of swivel grease?
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I've some minor leakage of swivel grease which I want to replenish. How do I measure the amount that's still in there and to which lvl should I add one shot swivel grease?
Thnx in advance! a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770360 27th Apr 2019 10:53am
markb110
Hi. I use a long zip tie and use that as a dipstick.
Hope that helps
Post #770397 27th Apr 2019 5:53pm
landy andy
Just shove half a tube in (per side) each year. If you over fill it just goes into the axle oil. No problem. No grease knackered swivel and joint.
Post #770398 27th Apr 2019 6:13pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
As above, if I am suspicious of a slight leak then half a tube in each side to be sure. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #770532 28th Apr 2019 3:00pm
Tdi4
Thnx, another job sorted. But to see if both sides leak equally (and I've filled them to the same lvl) I painfully designed a stub axle grease measuring kit. After a few hours of designing and prototyping I came up with this:
Does the job Thumbs Up and will see if I have to replace the seals in the future a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770616 29th Apr 2019 6:45am
Co1
^^^ Patent pending obviously?!
Post #770678 29th Apr 2019 1:20pm
Tdi4
No no!
World wide patents received. Did you really think I would post the Photo otherwise Rolling with laughter a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770680 29th Apr 2019 1:46pm
