Home > Puma (Tdci) > How to check level of swivel grease? |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I've some minor leakage of swivel grease which I want to replenish. How do I measure the amount that's still in there and to which lvl should I add one shot swivel grease?
Thnx in advance! a defender from 1984 pretending to be a puma with a touch of Range Rover |
27th Apr 2019 10:53am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2633 |
Hi. I use a long zip tie and use that as a dipstick.
Hope that helps |
27th Apr 2019 5:53pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
As above, if I am suspicious of a slight leak then half a tube in each side to be sure. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
28th Apr 2019 3:00pm |
Thnx, another job sorted. But to see if both sides leak equally (and I've filled them to the same lvl) I painfully designed a stub axle grease measuring kit. After a few hours of designing and prototyping I came up with this:
Click image to enlarge Does the job and will see if I have to replace the seals in the future a defender from 1984 pretending to be a puma with a touch of Range Rover |
29th Apr 2019 6:45am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3674 |
^^^ Patent pending obviously?!
29th Apr 2019 1:20pm |
No no!
World wide patents received. Did you really think I would post the Photo otherwise a defender from 1984 pretending to be a puma with a touch of Range Rover |
29th Apr 2019 1:46pm |
