Home > Puma (Tdci) > The newest motor I have ever owned |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Hi Nick,
Welcome. Assuming you bought it as a used approved Defender they should supply the correct service book for it. The service interval is 12 months / 12,000 miles so if it is a late 10 plate it may not have had it's first service. As others have said you should expect a courtesy car - my local dealer has always provided Freelanders with any work on previous Defenders. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
6th Jun 2011 2:50pm |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 |
Well-just got the 90 back from dealer. Request was to sort out the leaking door seals again. Basicaly the doors are not fit well, hence no compresion to form seal. It came back with additional scratches to the paintwork, and a bit of sealant to stick the seals in place. The valleter advised that the mechanic said not to turn hosepipe on the seals Another half day off work....not bad for 6 weeks ownership Does everyone else see light through the bottom corners of front doors (I can live with the draught and water coming up, I just don't want it peeing my legs and tools through from above )
This bodes the question-should I be able to wash my van without water ingress? |
21st Jun 2011 3:25pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
nope, my seals let no light through anywhere on the doors. No leaks either, pressure washing never lets water through front doors .... now the back door .. Guns and Landrovers .... anything else is irrelevant. |
21st Jun 2011 7:28pm |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
I think some newer ones may have been fitted with a better seal. Older pumas and Td5's had a square of foam glued into the bottom corner of the door, but this usually falls off after about a year. Think the idea is to let out the water that collects in the footwell whenever the landrover seems to get wet!! |
21st Jun 2011 7:48pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Not everyone. My 2010 90 xs is now 15 mths old. All doors seal well, even to a pressure washer. Foam blocks still in place. There are new 1 piece lower door seals available as fitted to the 2011 my Defenders. See here:-
http://www.defender2.net/forum/topic6370.h...door+seals LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
21st Jun 2011 8:48pm |
I think you should take it in to the dealers for an inspection. It cant have been put together right if it doesn't leak |
22nd Jun 2011 7:53pm |
I have owned many Land Rovers over the last 25+ years. I am no duck egg. Thanks for the constructive reply Matt. After hearing LR engineers sloppy recomendations-" not to wash using a hose pipe directed to the seals"
£20K + for a coulinder?? The poo is about to hit the proverbial fan! I'm sick of having to take time off work for a fault pointed out on the forecourt before purchachase!! |
22nd Jun 2011 8:26pm |
Would have thought you would have learnt about Defender build quality and construction, and dealership helpfullness by now, if you've owned land rovers over the last 25+ years |
22nd Jun 2011 8:45pm |
Oh, and I was only saying about my experience of the 3 defenders i have owned and at least 5 other defenders I know of within 2 miles of my house with regard to foam and water leaking into the footwells |
22nd Jun 2011 8:50pm |
Would have thought you would have learnt about Defender build quality and construction, and dealership helpfullness by now, if you've owned land rovers over the last 25+ years [/quote]
As stated in title-this is the newest vehicle I have ever owned. Stupidly, I have purchased a new ish vehicle. Should have saved cash and gone down the route of galve chasis, 200 TDi build Better the Devil you know |
23rd Jun 2011 7:31pm |
Yeah, I owned a 200tdi before, probably the best model of defender Landrover have ever built, everyday I ask myself why I ever sold it on and went for a newer model. |
24th Jun 2011 5:26pm |
Well it went into dealership again for the third time. Door seals still leaking (can see lots of light) Bloke that picked it up said they all leak, I replied that I have owned quite a few over the years with no leaks. Reply was - you were lucky I told him to take my vehicle and return with £20k of luckiness. If they all leak, why bother fitting flipping door seals!!!
6th Jul 2011 6:15pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
ring russell (warranty manager) at hillendale, explain the problem, book it in, tell him you need a courtesy car.
7th Jul 2011 12:48pm |
Good news It's not just me being a c**t They have confirmed that it leaks. The more leaks they fix, the more they find At least they are now serious about rectifying the fault. No more "they all leak" attitude Third time lucky??
7th Jul 2011 7:51pm |
