![]() | Home > Puma (Tdci) > The newest motor I have ever owned |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Nothing unusual there from a dealer and standard defender issues im afraid.
I would have expected/demanded a car - if picked up by LRE then they WILL get you one and are very good. Mike |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
I would call them up to arrange some warranty work and tell them that you want a courtesy car, that way they can't fob you off on Hertz or Enterprise.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
Welcome to the site
![]() No you are not being unreasonable. Remember you are under no obligation to use the same dealer to carry out warranty work, any franchised LR dealer can/will do so so you don't have to put up with them if you have the option of using somewhere else. You should definitely get a courtesy vehicle for warranty work - probably a Freelander 2. As for the service book, have you asked for the missing book from the supplying dealer - I assume it was a franchised LR dealer you bought it from? ![]() ![]() |
my td5 90 doesn't leak! looks like you got a right plum. |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Hiya Nick
![]() Welcome , you stalking me lol? You are not being unreasonable, all your issues are valid points which should be addressed under warranty. And yes, they should provide you with a courtesy car if available. Might be worth dropping a mail/call to Landrover customer relations [0870 5000500] www.landrover.com and seeing their reaction - worked for me lol Guns and Landrovers .... anything else is irrelevant. |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
Oreet Dave
![]() Should have known you'd be on here ![]() ![]() Apart from the couple of niggly bits, I am over the moon with the new motor. Just finnished decking the back out for the dogs-looking smart. Had it up Drumclog with the Difflock lads in the first week of ownership ![]() |
Strugling with the photo posting-these are without the storage boxes underneath. The sides are lined in plastic and joints welded.
Thats a cracking good set up mucker ... two seperate cages or one big one with two doors? Guns and Landrovers .... anything else is irrelevant.
One big cage with a removable divider.
Just having a swarm over the motor and generally making it home-what are all the yellow dabs of marker for?
Shows which nuts have been checked for tightness/correct torque.
Thankyou
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 350 ![]() ![]() |
Hi Nick,
Which dealer is causing you so much grief? Always interesting to know who is letting us down. To avoid the expensive 08xx numbers you can call Land Rover on 0121 722 2424 and ask for customer service. I would definitely speak to them and you will probably find them very helpful. As others have commented find yourself a decent dealer - Hillendale would probably work well for you if I have got your location right. Proud owner 110 Utility XS Ex RR Sport HST V8 Ex Td5 90 |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 684 ![]() ![]() ![]() |
Go and see Hillendale on M65 at Nelson, excellent service, there is praise on here from other forum users also. 130 Puma HCPU with an Artica 240LR Demountable Camper
