Home > Maintenance & Modifications > radio cassette removal |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Try here:
http://www.mudstuff.co.uk/Defender%20I.C.E%20Solutions.shtml Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
21st Jun 2011 6:42am |
Barry Member Since: 26 Apr 2011 Location: North East Posts: 137 |
Long time since I did this & it wasn't a Landrover but a couple of bits of bent coat hanger used to do the job , it was only something to push a spring clip back and allow you to pull the radio out.
May have changed to something more secure now but it used to work. Cheers 2011 Defender XS 110 Station Wagon - Rejected 2008 Discovery 3 XS Auto (Gone) 1997 Discovery ES Auto 300TDI (Traded in on a flat bed) |
21st Jun 2011 9:49am |
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 |
Did give this a try, the coathanger bits fit the hole but don't result in any movement |
21st Jun 2011 10:08am |
The image of the radio unit is right, but the tool looks like it's for a 4 hole rather than 2? I'll give them a ring though |
21st Jun 2011 10:14am |
When wiring up my auxilliary lights I just popped along to my local dealers and asked if they would be kind enough to release it for me which they did!!! If you go through life with your head in the sand....all people will see is an ar5e!!
21st Jun 2011 10:30am |
paullo Member Since: 14 Dec 2010 Location: Just Outside the M25 Posts: 47 |
Try a long 2.5mm allen key, I believe. I took mine out a few months back- about 3 mins (the bolts are quite long) to get both loose enough to pop out and the cassette / radio pulls out easy as after that.
Good luck |
21st Jun 2011 2:23pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
They are a to get out, just need to put something in the holes and pull like hell
21st Jun 2011 2:46pm |
Ask them directly: mud@mudstuff.co.uk Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
21st Jun 2011 5:32pm |
I gave Mud a call, and it seems that paullo was right, allen keys are the solution
21st Jun 2011 6:40pm |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
If its a genuine LR radio/cassette, Paullo is right, there are 2 allen headed bolts holding the head in NOT the tabs that require wire/prongs to remove, like most radios. The bolts are set back in the head a long way, so you wont see them without looking with a torch. Last edited by Matt on 21st Jun 2011 7:40pm. Edited 1 time in total |
21st Jun 2011 7:39pm |
Ha Ha, just seen you found the solution. |
21st Jun 2011 7:40pm |
