Home > Maintenance & Modifications > radio cassette removal
gambit
Hi
I am thinking of upgrading my head unit - when I bought my truck, there were no radio removal tools. The current unit is a Radio/Cassette with a single hold on each side.
Have looked in Halfords, but the only tools they have seem to be for either slots, or 4 point.
Thanks
Andrew.
Post #76915 21st Jun 2011 5:18am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Try here:
http://www.mudstuff.co.uk/Defender%20I.C.E%20Solutions.shtml Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #76924 21st Jun 2011 6:42am
Barry
Long time since I did this & it wasn't a Landrover but a couple of bits of bent coat hanger used to do the job , it was only something to push a spring clip back and allow you to pull the radio out.
May have changed to something more secure now but it used to work.
Cheers 2011 Defender XS 110 Station Wagon - Rejected
2008 Discovery 3 XS Auto (Gone)
1997 Discovery ES Auto 300TDI (Traded in on a flat bed)
Post #76950 21st Jun 2011 9:49am
gambit
Did give this a try, the coathanger bits fit the hole but don't result in any movement Big Cry
Post #76953 21st Jun 2011 10:08am
gambit
Theater wrote:
Try here:
The image of the radio unit is right, but the tool looks like it's for a 4 hole rather than 2? I'll give them a ring though
Post #76955 21st Jun 2011 10:14am
K9F
When wiring up my auxilliary lights I just popped along to my local dealers and asked if they would be kind enough to release it for me which they did!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #76957 21st Jun 2011 10:30am
paullo
Canada
Cassette Radio Removal
Try a long 2.5mm allen key, I believe. I took mine out a few months back- about 3 mins (the bolts are quite long) to get both loose enough to pop out and the cassette / radio pulls out easy as after that.
Good luck
Post #76987 21st Jun 2011 2:23pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
They are a Censored to get out, just need to put something in the holes and pull like hell
Post #76990 21st Jun 2011 2:46pm
Theater
gambit wrote:
Theater wrote:
Try here:
Ask them directly: mud@mudstuff.co.uk Marco
Post #77026 21st Jun 2011 5:32pm
gambit
I gave Mud a call, and it seems that paullo was right, allen keys are the solution Smile
Post #77039 21st Jun 2011 6:40pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Re: Cassette Radio Removal
Good luck
If its a genuine LR radio/cassette, Paullo is right, there are 2 allen headed bolts holding the head in NOT the tabs that require wire/prongs to remove, like most radios. The bolts are set back in the head a long way, so you wont see them without looking with a torch. Thumbs Up
Post #77050 21st Jun 2011 7:39pm
Matt
Ha Ha, just seen you found the solution. Whistle
Post #77051 21st Jun 2011 7:40pm
