Home > Puma (Tdci) > Grrr Grr Noise |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 |
I know what you mean and I get it too, got used to it and it only happens every now and then
Not much help but at least you are not on your own |
18th Feb 2009 2:19pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Don`t let it labour, it causes a lot of transmission vibration
18th Feb 2009 3:11pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Try taking the phone out of your pocket
19th Feb 2009 3:36pm |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
Mine makes this type of sound too - definitely seems to come from the rear somewhere - but I'm not labouring the engine when I hear the noise. On mine, it's noticeable in 4th at 60km/h but doesn't occur at 50km/h in 4th nor at 70 in 5th (or any other speed/gear really). Although I do notice it crawling along in 2nd.
Because of the driving situations/conditions which induce this noise - I don't think it's the rear diff. I suspect there is some component which is loose and perhaps vibrating at certain revs/speeds. The heat shield between the muffler and fuel tanks was slightly loose and was just touching the chassis rail. I tightened it up as best I could - it's almost impossible to get a screwdriver onto the screws given it's position, and bent it slightly away from the chassis rail. I haven't had a chance to drive it yet and see if this solves the problem but I hope so as it's driving me nuts. LR dealer reckons they can't hear any abnormal noise. |
23rd Feb 2009 10:03pm |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 |
I had a drivetrain specialist(not LR) lift the vehicle off it's wheels on a lift then lie under the vehicle and listen while I drove in the same way that would duplicate the noise, the noise came from the splines on the propshaft.
It is the most effective way to find a noise like this but make sure that safety precautions are taken or it is done buy a person with the correct equipment and expertese to do something like this. |
24th Feb 2009 6:25am |
Hi there Fontuin
Can you elaborate? When you say the splines, they are just grooves cut in the shaft, was it that the shaft had play in it or something? Thanks in advance |
24th Feb 2009 8:56am |
The splines on the Puma are different to that of the Td5 in that it has a type of a 'bearing', removing the prop shaft and extending it fully reveals the 'bearing'. I suspect that the bearing is the culprit, there is no noticable play on the splines. Swopping my prop shaft with that of a Td5 elliminates the GRRR and reduces the amount of backlash I exeperience slightly, fitting my propshaft to LRs demo vehicle duplicates the GRRR. I have not cured the GRRR because LR have not been very helpfull in offering me a solution, the vehcile is still under warantee, I wait for thier promised call. It has been doing it since new. Hope this gives you some clarity. |
24th Feb 2009 9:13am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Shrop. lad. I've noticed at common thread here....... none of those with this problem have a blue 110 |
26th Feb 2009 9:06am |
JohanH Member Since: 13 Feb 2009 Location: Trondheim Posts: 26 |
Hi lads,
my first post here... I have been reading the forum with great interest. I actually also have noticed a grr grr noise from the back when driving slowly in a high gear. Yesterday I went to the local dealer here in Norway and told them about it, when I collected the car in the afternoon they told me that the fastening bolts for the back axle had come loose! Now everything is tightened up and not a hint of any grr grr sound anymore! I also used to hear a slight CLONK sound when picking up drive or changing gear, and these were off course also cured by tightening the bolts. So at least my grr grr noise was caused by loose bolts Cheers, Johan H Defender 110 -08 Audi UrQuattro -88 BMW 2000 touring -73 Mercedes-Benz 250 -75 Alfa-Romeo 156 -98 |
20th Mar 2009 8:26am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
Hi JohanH would you please specify which bolts did they look at? thanks MK Puma 110" SW ............................................................. Earth first. Other planets later |
20th Mar 2009 2:19pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Check the rear diff both our 110's destroyed the rear diffs within 50 miles from new. My Utility being an early car actually came with a TD5 prop. Its chewed several UJs so far the TD5 UJs are smaller than the Puma. The UJs were replaced under warranty. The prop bolts where the prop bolts to the park brake drum come loose every 2000 - 3000 miles.
20th Mar 2009 5:35pm |
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 |
Sell it
13th May 2009 9:08am |
slocum Member Since: 16 Oct 2008 Location: Italy Posts: 19 |
Is it a noise like this?
Since the first kilometre I found this anomalous and disturbing vibration coming from the rear axle of my Puma. |
13th May 2009 5:35pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
THats one bad transmission noise...not right - when do you get your new diff?! Mike |
13th May 2009 6:20pm |
