![]() | Home > Technical > Windscreen washer twin jet head |
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 ![]() |
Yes. Soak the new one in hot water before separating, try the “search” key, a common problem, lots of info on here. Time is precious, waste it wisely...
Defender 90 D200 |
Tractorman Member Since: 08 Jul 2016 Location: Inverclyde Posts: 41 ![]() ![]() ![]() |
Many thanks Blacksheep - that has been very helpful
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
You can, but at least on the older vehicles it had a habit of dismantling itself again. Not sure if the Puma ones are the same part, it's a newer LR.... part number. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 ![]() ![]() ![]() |
Thanks, as always for the tips: I managed to separate the parts in hot water and re-attach to to what remained on the car (with some glue to try to keep in place).
Definitely saved time and effort ![]() |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I hit the top of mine clean off with a foam brush back in the winter. I done exactly the same thing. Soak in hot water, line it up with what's left showing on the bulkhead and a smart tap with my hand and it clicked back into place 😁👍
