Home > Maintenance & Modifications > Is my rear diff shot? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20448 |
Did the Prop UJ's all seem okay and was the flanges on the transfer box / diff secure?
I'd take a look at the front as well, because sometimes it can seem opposite to the location you think it is. There is the A frame ball joint too, rear damper bushes etc justto name but a few other posdibities. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
22nd Apr 2019 3:22pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3682 |
Thanks Steve. UJ have no play at all. Damper bushes are new. A frame I haven’t checked, so will have a look at that as well as the front.
22nd Apr 2019 3:56pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
compare the play in the front diff to the rear that will give you some idea what normal is, mine had about 5-10 degree's of free play. a clunk could easily be the adaptor shaft at that mileage, any rust from the intermediate shaft housing? DEFENDER 90 TDCI XS,
22nd Apr 2019 6:28pm |
Thanks. If it were the adaptor, would the wheels being in the floor not prevent the prop shaft from turning? I’ll get under tomorrow and take some pics of how far it is moving and other odds and ends.
Thanks Col |
22nd Apr 2019 6:36pm |
Checked a couple more things tonight. Marked up the handbrake drum and then twisted the rear prop shaft with the handbrake off. The result is this much movement:
Click image to enlarge Then marked the front at the diff end with a line corresponding to the centre of the nut closest to the mark. Rotated and this is the result (the flash has hidden the white mark a bit, but hopefully you can make it out: Click image to enlarge I guess what I don’t know is whether this is normal. From what I could see of the a frame, the bushes looked ok, but very hard to tell. When the vehicle sets off, the slack in the drive line is taken up before the wheels start to move by the same degree as the marks dictate above. Similarly, when parked on a slope, hand brake on and foot brake released, it rolls in the direction of the hill by the same amount. Any thoughts? Is this perfectly normal?! |
23rd Apr 2019 5:51pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
^^That prop uj looks lacking in the grease department. When did you last grease the propshafts?
23rd Apr 2019 6:45pm |
About a month ago. Is has been cleaned since then!
23rd Apr 2019 6:55pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 335 |
I have similar levels of play in front & back diffs.
I'm not sure what's the norm so interested in this thread. |
23rd Apr 2019 7:30pm |
there are a couple of threads on here regards diff play some with videos, without witnessing it it is hard to tell, you could drop the oil and see if it has any metal in it (put a strong magnet in the oil flow) if it has gained some play because something has worn out it will result in metal in the oil. DEFENDER 90 TDCI XS,
23rd Apr 2019 7:33pm |
Thanks LR90, oil was changed about 2k ago and no change in the amount of slop!! I’ll have a search for the vids.
23rd Apr 2019 7:36pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
As far as I know you need to remove either end of both propshafts to check on actual play for diffs and the Lt230. All have a fair amount of play even when new. Puma 110" SW
23rd Apr 2019 8:48pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8053 |
So play front and rear about the same by the looks of the marks considering drum is further out. I reckon that's the same play as my 78k 90, 51k 90 and 72k 90.
Have you check radius arm bushes? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
23rd Apr 2019 9:55pm |
I’ll check the radius arm bushes, but how would that account for play in the diff? Or is there actually nothing wrong with how much okay I’m demonstrating?
With the prop shaft removed, there is the same amount of rotation at the diff flange. Thanks for all the help so far. |
24th Apr 2019 5:12am |
https://www.defender2.net/forum/topic40945...ntial+play
https://www.defender2.net/forum/topic16601...ntial+play https://www.defender2.net/forum/topic27466...ntial+play https://www.defender2.net/forum/topic1508....l+backlash https://www.defender2.net/forum/topic13545...l+backlash DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
24th Apr 2019 5:17am |
