Home > Puma (Tdci) > Progressive coils |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
We have a doubt with MK regarding the progressive coils.
The upper part of the front coils appear to be touching each other. This is OK? see the picture. Click image to enlarge Are yours looks similar? Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
24th Feb 2009 2:50am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I think that's the standard set-up.
If you completely extended the spring, you'd see that it is progressive IIRC. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
24th Feb 2009 9:26am |
This is just that we are trying to confirm if this is the normal setup or not. Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
24th Feb 2009 2:22pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
24th Feb 2009 2:36pm |
After checking other information in other sites appears to be OK as it is.
If you like to check the suspension height: Front: 72 ± 15 mm Rear: 130 ± 15 mm Thanks to all. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
25th Feb 2009 12:27am |
+/-15mm is quite a big (LR) error. Those +15 mm account probably for the separation on new springs. Puma 110" SW
25th Feb 2009 1:27am |
