![]() | Home > Puma (Tdci) > Hot air from Puma (New Kenya CKD) |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
what color is that beauty?
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Had a similar problem on a 200 tdi except in my case the thermostat was stuck open and it was difficult to get any heat from the heater on a cold day.I remember buying a replacement and changing it in the yard of the independent from whom I bought it-tools etc supplied from the workshop.When I was hunched over the engine getting it changed someone landed in with a well used 90 whose wiper parking switch had packed up. Ended up changing that just before heading off to lunch with the lads who were busy with something extremely awkward at the back of a Discovery engine-new type. As it was a simple job to change the parking switch they asked me to do it.Usually end up pretty dirty when I come home from there. Highly educational and always good "craic" 1982 88" 2.25 diesel
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
Where is such thermostat located
![]() ............................................................. Earth first. Other planets later |
Glad you got it fixed. So with the CKD do you get to pick custom colors? I thought you couldnt get a CKD anymore.
Puma or 200 tdi? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
