Home > Puma (Tdci) > Hot air from Puma (New Kenya CKD)
TwoDreadlocks
Kenya
Nice to finally join you all... great forum!
Finally collected my 110, brilliant machine.
Here's some pictures (as tradition goes with this forum)..
It's a new CKD from Kenya, without any of the bells & whistles.
Standard steel rims, no Air conditioning, no ABS or Traction Control, no accessories, as basic as it gets really.
The engine is also the T version (non-European S version), so no Catalytic converter, and i'm assuming no EGR valve either (?).
Strange problem though..
Done a few hundred kms with it so far... only thing that seems strange to me is after a few kms of driving and the engine area starts heating up, i get constant trickle of hot air from the vents. This happens even if the fan is off - when it's on, and the temperature selector is on the coolest point, the air still feels like a dragon's breath!
This is all regardless of whether inflow lever is on the "out to in" or "recirculation" options.
So considering all the eccentricities of a defender, my question would be: is this normal?
If not, any clues as to what may be wrong?
Thanks Smile[/img]
Post #76594 19th Jun 2011 6:04am
22900013A
Sadly it is normal these days, and not just on Landrovers, Mercedes sprinters are the same. My puma blows warmish air even when on the cold setting without aircon, and also the two outlets tend to have noticeably different temperatures. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #76595 19th Jun 2011 6:29am
LR90XS2011
Cant comment on you problems but love the Land Rover and the Road! DEFENDER 90 TDCI XS,
Post #76596 19th Jun 2011 6:39am
BigMike
how's your coolant level? it shouldn't be doing that.
Post #76605 19th Jun 2011 8:12am
Happyoldgit
110 looks great Thumbs Up
I never get really cold air out of mine unless the a/c is on. Steve.
http://forums.lr4x4.com
Post #76608 19th Jun 2011 8:18am
22900013A
Same on mine. I think this is pretty normal. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #76609 19th Jun 2011 8:21am
Lorryman100
Most cars (non climate control) will let in air when moving through the heater vents as air is still forced through the matrix by the movement of the car. However Landies don't have a heater inlet pipe at the front of the car to cause this as it's mounted on top of the left wing (RHD). Mine doesn't do it, when it's cool outside there is no heat coming through the vents unless I switch the fan on Confused You may have a faulty temp selector dial, do you get any variation in the temp at all when using the temp dial? When using the circulation/outside air lever do you get a satisfying clunk when selecting? Have you checked the bulkhead wiring bungs are fitted as the heat could be coming from the engine bay through the bulkhead? Are the 2 drainage teets fitted on the heater air inlet box, may be a cause for the warm air from engine bay being forced into heater manifold. Or it could be the fact you live in a hot climate and that's the air temp anyway. Anyways I would take it back to the dealer to fix as it will be in warranty. These options are just me thinking out loud, so if you cant get to the dealer I would take the centre dash panel off and check the heater controls are moving when you turn them and basically just visually check the heater system from the dash to under the bonnet.
Do as BigMike says and check the coolant level but the normal indication for low coolant is the heater not blowing hot air just cold. Then again do you get cold air in Kenya? And nice Landy by the way Thumbs Up
Post #76611 19th Jun 2011 8:50am
BigMike
It's more as a check to see the engine isn't running hot as we all know the standard temp gauge has too much range without the needle moving. If it's hot then warm air could easily be moving into the passenger area. if the header tank level is normal then it can be partially discounted but doesn't neccessarily mean there isn't a heat/overheat issue.
After a decent run I'd also take off the oil filler cap and have a sniff, the header tank cap too. on the latter, if it smells a little like curry then that would indicate excess heat.
Post #76617 19th Jun 2011 9:03am
MK
I would check on it. Here in we get up to 35ºC and the outside air feels a bit over that as it passes through non isolated inlet tubes beside the turbo and exhaust manifold before reaches the cabin. What engien oil is supposed to be used over there? Puma 110" SW
Post #76636 19th Jun 2011 10:42am
JSG
Welcome - love the look of your 110 Thumbs Up John
2011 Tdci 110 CSW XS
Post #76663 19th Jun 2011 1:37pm
spudfan
Ireland
You will have the factory fitted automatic dropping rear windows. This is fitted at no charge and should be ideal for warm Kenyan conditions in helping keep you cool.If you are not sure you have this feature or not you will notice it while driving as your rear passenger door windows will open ever so slightly of their own accord. Just remember to check when you park up somewhere.What tyres are fitted to your vehicle? Welcome to the family and the forum. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #76695 19th Jun 2011 5:32pm
TwoDreadlocks
Kenya
Thanks for all the feedback guys Smile
Been all over today (on road and some off road) - what a beast, love the effortless torque!
I'm in Nairobi now, with temperatures always between 18~26°C - very rarely hotter or colder and not by much (thanks to 1700m altitude on the equator).
The temperature of air coming into the cabin from the vents is definitely heated from the engine, as it's always nice & cool during the start of the ride, but starts getting fiery after 30mins of driving.
Coolant level looks fine, spot on the mark. Engine does feel moderately hot after long drives.
Yeah there is an obvious variation.
In the morning, on cool setting it's perfectly cool, on hot setting it's hot.
After an hour of driving, on cool setting it's warm, on hot setting it's like a nuclear reactor!
No i haven't, frankly not sure how to go about it.
The good news is that the selector controlling where the air comes out works fine.
ie. the airflow follows the right output routing (big round vents only / windscreen only / footwell + dashboard) - only it also does the same by trickling in the heat through whatever's been selected when the fan is still off.
Where do i find these? This sounds very likely tho, as it's definitely hot air from under the bonnet finding its way into the cabin.
Thanks, will check.
The car still has whatever the assembly line put in. Still haven't had a chance to find out exact brands, though i'm advised fully synthetic engine oil, that apparently only Shell petrol stations stock.
Thanks again for all the cool comments & feedback guys.
Spudfan, it's rolling on standard Yokohama tyres that come default on the steel rims. They feel quite alright on & off the road.
Post #76717 19th Jun 2011 7:28pm
Lorryman100
Took this from another post I did:
Lorryman100 wrote:
holmessato wrote:
I only get water in the footwells on the passenger side front.
Also check that the Heater air intake teets are not blocked. There are two of them and if blocked the heater intake will fill with water and leak into the passenger footwell. Took me ages trying to find where the water was coming from, in the end I found it was blocked teets.
You can see the part of the heater intake grill (left wing top) in the bottom right of the picture to give you orientation. There are two draining teets arrowed red.
Post #76718 19th Jun 2011 7:39pm
flying_low
Kenya 2011 Defender 110 Puma 2.4 SW Keswick Green
Nicee one Fady!!!!
Hey man.. sweet wheels!!
Mine's living in the Masai Mara already.. will put some pics up as soon as i have managed to get out a bit..
Just get onto that car with a socket set, and pick up a folding torx wrench set from nakumatt, and go over every nut and bolt and screw you can reach inside and and outside/under the car..
Whatever you do.. don't stress out too much over it.. enjoy it!
Cheers dude!
Thumbs Up
ps: ....where did you get the info that the Kenya CKD's from KVM don't have the EGR valve? I'm pretty sure they do, but don't mind being corrected if i'm wrong.. I hear it every time the engine is shut down...sounds like a dog panting about 5 times real fast.. From reading on this forum, i understand thats the EGR self cleaning.. ??
Does yours not do that??? 2011 110 Tdci
1982 Range Rover V8 Classic (Gone)
Post #76851 20th Jun 2011 4:55pm
Defendit
Australia 2011 Defender 110 Puma 2.4 SW Keswick Green
Re: Hot air from Puma (New Kenya CKD)
Thanks Smile[/img]
Had the same problem and wrongly assumed it may be normal. It's not.
The problem in my case was the heater outer cable which was not properly secured and sliding at the valve end. It's a very basic design and I suspect many will be affected.
Heater was either on or off but never fully off. Now it's adjustable and no heat at all when set to cold.
Post #76894 20th Jun 2011 9:31pm
