Home > Maintenance & Modifications > Bilstein shock install help |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
The upper washers have the tapered side towards the bush.
Again the same with the lower bushes also. šš» No Guts, No Glory. š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
18th Apr 2019 11:54am |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 370 |
Thanks Custom90,
That makes sense, on the bilstein at the top, there is only one washer in the pack, the original had 2?! Is that normal? My options seem to 2 large washers at the top but then Iām short one at the bottom or 1 at the top and 2 at the bottom! Mmmm Click image to enlarge Click image to enlarge 2006 Defender Double Cab- Zambezi Silver |
18th Apr 2019 12:11pm |
There should be 2x washers at the top, they should be identical too.
If you haven't got two of them they must be missing. No Guts, No Glory. š¬š§š“ó §ó ¢ó „ó ®ó §ó æš“ó §ó ¢ó ·ó ¬ó ³ó æš“ó §ó ¢ó ³ó £ó “ó æš®šŖšŗšøā½ļøš¢ļøāļøš§°šŖ |
18th Apr 2019 1:11pm |
Ok, that makes sense then.
The two identical ones on the top, then on the bottom, the stepped one, bush, then through axl, bush and I must have to use the wash that was existing then. As they only supplied one of that type. Click image to enlarge Cheers 2006 Defender Double Cab- Zambezi Silver |
18th Apr 2019 1:42pm |
