![]() | Home > For Sale & Wanted > [For Sale] Brackets for 52" LED Light Bar |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2316 ![]() ![]() ![]() |
I bought these off ebay at £40... Unfortunately they are not compatible with my JLR safari raised air intake.
Sell for £25 posted These brackets are custom made to fit into Land Rover Defender roof gutters and hold a 52" led light bar with 8mm bolt holes. Brackets are laser cut, machine bent, and powder coated in black. All bolts and nuts are zinc coated. Each set contains: 1x pair of brackets (for each side) 4x 6mm bolts 4x 6mm washers 4x 6mm nylon nuts 2x 8mm bolts 2x 8mm Wurth lock washers rubber strip (to stop whistling noises) Same as these ones https://www.ebay.co.uk/itm/163000671701 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab |
bump > 110 XS Double Cab
buy me plz > 110 XS Double Cab
TobyMellin Member Since: 27 Dec 2017 Location: Manchester Posts: 16 ![]() ![]() ![]() |
I’ll take these
Sold > 110 XS Double Cab
