Home > Td5 > Noise fuel pump |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5692 |
Sounds like it could be your injector seals. Run pump prime before starting tomorrow and see how noisy pump is, and what start running is like.
10th Apr 2019 7:00am |
Gozy Member Since: 02 Apr 2016 Location: Sidbury Posts: 43 |
Hi Andy still much the same. Noisy pump all the time until starting. Starts on second or third time Lumby then clears and noise of pump probably goes. Noise of engine takes over. But it also can start normally but with the noisy pump which again I think goes after starting. Check the battery all seems ok and when starting.
13th Apr 2019 6:04am |
All if a new pump is required questions are as always, make ,patterned, oem ,genuine and best price found thanks. Gozy
13th Apr 2019 6:10am |
