Home > Td5 > Noise fuel pump
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
Noise fuel pump
Please help. Just developed a noisy fuel pump when turning on ignition. When it had finished ,started engine but very Lumby then cleared ,but drove fine. should I carry on driving her ? Me thinks check things out ! Any ideas thanks Gozy.
Post #767939 9th Apr 2019 11:51pm
landy andy
Sounds like it could be your injector seals. Run pump prime before starting tomorrow and see how noisy pump is, and what start running is like.
Post #767957 10th Apr 2019 7:00am
Gozy
Hi Andy still much the same. Noisy pump all the time until starting. Starts on second or third time Lumby then clears and noise of pump probably goes. Noise of engine takes over. But it also can start normally but with the noisy pump which again I think goes after starting. Check the battery all seems ok and when starting.
Post #768361 13th Apr 2019 6:04am
Gozy
All if a new pump is required questions are as always, make ,patterned, oem ,genuine and best price found thanks. Gozy
Post #768365 13th Apr 2019 6:10am
