Home > Maintenance & Modifications > Painting plastic parts
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Ok have a couple of plastic parts to body colour. Always just primed and top rattle can but wondering if there was any paint experts on here that could offer any pro tips
Post #768208 11th Apr 2019 8:49pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Just make sure you use a plastic primer. Wipe down before spraying with an alcohol wipe to remove dust and muck. Spray in a warm room, not outside in the cold. Build up the layers slowly. Do a test spray to get a feel for the rattle can.
Post #768209 11th Apr 2019 9:01pm
Or you could use Panel wipe, go slow on plastic though to avoid static as it is prone to that.
And as mentioned plastic primer is a must, a red scotch pad to key the surface before priming is ideal.
You can do a guide coat too before flatting the primer prior to base coat too if you wish. This gives you the perfect finish.
I also like to wipe off any wipe residue once dry too, as this can be present so I tend to panel wipe then when flashed off dry wipe off lightly.
Tack cloths are also good too have.
I use all Upol mainly for the above.
Should you get any clouding in clear coat. (Excess humidity when spraying - try and avoid!)
A heat gun carefully used will often draw the moisture out to full gloss. $W33T $0U7H3RN $UG4R
Post #768222 11th Apr 2019 10:07pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
If you are looking repainting black plastic I would recommend Buzzwelds Plastic in one.
Really simple: clean, key, (clean again) and spray.
http://www.buzzweld.co.uk/pio.html
I used it to redo the front grill and light surrounds! Excellent results! last page of my thread has a few before and after photos... and the make shift spray booth!
https://www.defender2.net/forum/topic49869-60.html Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #768254 12th Apr 2019 9:06am
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
+1 for buzzweld, great stuff which has completely transformed some old trim I bought. also very easy to use and apply
Post #768322 12th Apr 2019 6:48pm
I recently painted a couple of light surrounds to body colour and was pleased with the result after using plastic primer bought from Halfords. It's strange stuff though; it comes out as a sort of mist that remains slightly tacky until coated with regular primer. Darren
Post #768349 12th Apr 2019 9:19pm
L110CDL
I did the same as LRA, with the same good resuts Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #768767 15th Apr 2019 9:32pm
