![]() | Home > Maintenance & Modifications > Painting plastic parts |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
Just make sure you use a plastic primer. Wipe down before spraying with an alcohol wipe to remove dust and muck. Spray in a warm room, not outside in the cold. Build up the layers slowly. Do a test spray to get a feel for the rattle can.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Or you could use Panel wipe, go slow on plastic though to avoid static as it is prone to that.
And as mentioned plastic primer is a must, a red scotch pad to key the surface before priming is ideal. You can do a guide coat too before flatting the primer prior to base coat too if you wish. This gives you the perfect finish. I also like to wipe off any wipe residue once dry too, as this can be present so I tend to panel wipe then when flashed off dry wipe off lightly. Tack cloths are also good too have. I use all Upol mainly for the above. Should you get any clouding in clear coat. (Excess humidity when spraying - try and avoid!) A heat gun carefully used will often draw the moisture out to full gloss. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
bogwert Member Since: 02 Sep 2016 Location: Dundee Posts: 194 ![]() ![]() ![]() |
If you are looking repainting black plastic I would recommend Buzzwelds Plastic in one.
Really simple: clean, key, (clean again) and spray. http://www.buzzweld.co.uk/pio.html I used it to redo the front grill and light surrounds! Excellent results! last page of my thread has a few before and after photos... and the make shift spray booth! https://www.defender2.net/forum/topic49869-60.html Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW ![]() |
deaallen Member Since: 15 Feb 2016 Location: Basingstoke Posts: 266 ![]() ![]() ![]() |
+1 for buzzweld, great stuff which has completely transformed some old trim I bought. also very easy to use and apply
I recently painted a couple of light surrounds to body colour and was pleased with the result after using plastic primer bought from Halfords. It's strange stuff though; it comes out as a sort of mist that remains slightly tacky until coated with regular primer. Darren
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
I did the same as LRA, with the same good resuts
