Home > Technical > Noise when turning truck off... |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2300 |
Is it like a chatter chatter chatter sound? If so it’s the EGR self cleaning procedure > 110 XS Double Cab
3rd Apr 2019 7:01pm |
3rd Apr 2019 7:03pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
Google EGR valve DEFENDER 90 TDCI XS,
3rd Apr 2019 7:38pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
That's it but the clatter is louder now😲
Any idea how much the part is ? Puma 2.4 Thanks all |
3rd Apr 2019 7:43pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5172 |
can you not just remove it and bin it off? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
4th Apr 2019 5:08am |
there are loads of threads on here regards the EGR try the search function most suggest an increase in noise indicates a clean or replacement is required DEFENDER 90 TDCI XS,
4th Apr 2019 5:10am |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 |
The part number is LR006650 - £150ish for genuine. You might go through the threads and see if you want to remove it/isolate it. But if you do want to replace it I happen to have a spare (never fitted as I had the existing one isolated as part of a remap) - new in box (I think with the gaskets) - you're welcome to it for £60 plus the postage? Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
4th Apr 2019 8:48am |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
My new EGR was actually much noisier than the old one. I replaced it because it was repeatedly throwing up one or more warning codes. I seem to remember reading that if blanking-off the EGR you need to write it out of the ECU but stand to be corrected on that one.
4th Apr 2019 10:13am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
You only have two options;
1) Replace for new. Standard map tune. But it will need replacing again at a later date. 2) Fit a blank inlet side and get a tune with EGR shut permanently. This way is permanent and if combined with fuel additive I would say cleaner and more efficient in the long run full stop. There is certainly an MPG increase with both and definitely not a placebo. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
4th Apr 2019 12:32pm |
