Home > Puma (Tdci) > Mantec wading kit for Puma - why is there none?
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
I'm going to buy a Mantec RAI for my Puma and see there is no wading kit for the Puma model, although there is a kit for each of the other models including the TD5. Any ideas why this is? Is it due to the RAI not really being a snorkel so you shouldn't need breather pipes in the first place?
Post #76581 18th Jun 2011 9:09pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi,
There was a post about this a while back..you can get one if you get in touch with Devon 4x4. I would think its because RAI is not really a snorkel like you said. Even if you sealed it you have the other electronics to sort out..
Jack
Post #76588 18th Jun 2011 10:27pm
TJ101
Copy of a mail i had, back in 2008 from Mantec,,,, probably changed now ?? Question
Quote:
The new 07 Defenders do not require wading kits, this has been confirmed by Land Rover. Wadings can only be used with 2006 prior models.
Make of that, whatever ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #76672 19th Jun 2011 3:07pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
well i just exstended all my breathers which is surely what a wading kit is ?
loads of nylon air pipe and 6mm conectors
job done
still have gearbox to do though 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #76678 19th Jun 2011 4:04pm
BigMike
LR says that because the also say that the max wading depth is half way up the hubs, therefore not over the standard breathers. They couldn't really then endorse a breather kit as that would surely be saying "wading deeper is fine, just get a breather kit"
oh, also, the mantec RAI is easily a snorkel if you seal the joins from the wing pipe to the first pipe and then to the airbox. add some instant gasket to the airbox and you have a snorkel
Post #76688 19th Jun 2011 5:07pm
Odin
Thanks, sounds as though there's some warranty concerns but with the RAI fitted I should be ok taking the water level above the top of the wheel rim - otherwise the Defender is getting worse over time!
Post #76746 19th Jun 2011 9:45pm
BigMike
as long as its sealed, yes
Post #76753 19th Jun 2011 9:57pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
The earlier post on this subject said that the standard fit breather pipes were reasonably high up in any case. However, Devon 4x4 fitted extension pipes supplied by Mantec (ie TD5 breather kit I think) so that the breathers finished at the top of my Safari Snorkel.
Other posts have noted that you will need to seal the air filter box drain holes to make the system fully waterproof assuming that you have sealed all the other joints as mentioned above
The part number on my invoice is 10-WK3-TD5
Post #76867 20th Jun 2011 6:50pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
What about the plug on the accelerator pedal, might be worth waterproofing that as well, not sure what would happen if it became submerged, I'm sure someones tried it, might be ok Original Member Pie n Pea Club.
110 HCPU Tipper
Post #76872 20th Jun 2011 7:30pm
yan75020
France 2007 Defender 110 Puma 2.4 CSW Alpine White
Hi,
There is a breather kit for puma.You can find it to gwyn lewis. I buy it' s a good product.
Post #77058 21st Jun 2011 7:54pm
BigMike
but you need to drop the gearbox to get that breather on?
Post #77146 22nd Jun 2011 4:08pm
