Home > Puma (Tdci) > Need a new Radiator . |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
You might want to look at Alive tunings options.
Much depends on budget really. 👍🏻 KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
31st Mar 2019 6:50pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 910 |
I'll probably be shot down in flames here, but you could try a bottle of Forte radiator leak sealer (I can't post a link from my phone I'm afraid - search on Amazon). It's brilliant on minor leaks.
I used it on my old Citroen Berlingo as the heater matrix leaked and was a major job (dash out) to swap. It lasted perfectly for four years and then I sold the van. I quite understand if you'd prefer a new rad though. |
1st Apr 2019 5:58am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17537 |
Mine started leaking about 8 years ago and I replaced it with a decent aftermarket via the local factor. The replacement has lasted longer than the original, and (at least so far) has not leaked at all. It was a fraction of the cost of a genuine one, and much better value.
1st Apr 2019 7:29am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 743 |
What about an Allisport one? They're expensive but seem to be OK and even a bit bigger than the factory units with no plastic bits.
I was actually considering them when I had a radiator leak scare that just turned out to be a hose that was not reconnected properly. |
2nd Apr 2019 1:52am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Does the factory one have the crappy plastic end tanks like the intercooler? Those seem to be a weak point, 2014 Keswick Utility 2.2
2nd Apr 2019 5:55am |
Yes, I believe they do
2nd Apr 2019 7:19am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8150 |
Your genuine 14 plate one leaks after 5years which to me would say genuine are not worth the extra £££·
I fitted an all makes one to my 07 plate 2 years ago, fraction of price and all ok. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Apr 2019 7:38am |
Does the All Makes one have the plastic bits too?
2nd Apr 2019 8:10am |
Advanced Factors Site Sponsor Member Since: 06 Jun 2013 Location: Southampton Posts: 180 |
Hi Howard,
We have this available from stock. Please follow link below. Reagrds Paul. https://www.advancedfactors.co.uk/pcc00102...1179-p.asp PDK000100 Radiator Defender Td5 & Puma Nissens OE Quality MPN: PDK000100, 64311A WARRANTY: 2 Year Warranty Brand: Nissens £156.17 Inc. VAT £130.14 Ex. VAT Paul Redding +44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts |
2nd Apr 2019 9:17am |
It was a Nissens radiator that I fitted (see post above). I couldn't remember the name, but the moment I saw the name it came back.
I have been completely satisfied with the one I fitted, it is every bit as good as the original Landrover one (and has already lasted longer that the factory radiator). |
2nd Apr 2019 9:43am |
yes Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Apr 2019 10:05am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 |
I believe Nissens is the OEM for Land Rover. Mine is the original LR one which is now 14 years old, Quite happy with that so I will replace with the OEM Nissens one. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
2nd Apr 2019 11:27am |
Howard Member Since: 06 Nov 2012 Location: Oxfordshire Posts: 42 |
Thanks for all the posts, rad on order from Paul at Avanced Factors
4th Apr 2019 6:10pm |
Understand you've made your purchase, but another bit of 'anecdata' for those who visit this thread in the future:
I got Allmakes 'OEM', no thoughts of 'what is this junk!?' when I inspected it (that I've had with other aftermarket parts) and it's been working fine since install. Solved the bowel problem, working on the consonants... |
5th Apr 2019 10:43am |
