Home > Puma (Tdci) > Need a new Radiator .
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
I was surprised to find the radiator core on my 2014 2.2 has developed a weep. No evidence of damage or impact.
Should I replace with a genuine L R rad or is there a quality aftermarket option available?
Thanks
Post #766275 31st Mar 2019 7:32pm
You might want to look at Alive tunings options.
Much depends on budget really. 👍🏻 WeWillWin🇬🇧🇺🇸
Post #766278 31st Mar 2019 7:50pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I'll probably be shot down in flames here, but you could try a bottle of Forte radiator leak sealer (I can't post a link from my phone I'm afraid - search on Amazon). It's brilliant on minor leaks.
I used it on my old Citroen Berlingo as the heater matrix leaked and was a major job (dash out) to swap. It lasted perfectly for four years and then I sold the van.
I quite understand if you'd prefer a new rad though.
Post #766336 1st Apr 2019 6:58am
Mine started leaking about 8 years ago and I replaced it with a decent aftermarket via the local factor. The replacement has lasted longer than the original, and (at least so far) has not leaked at all. It was a fraction of the cost of a genuine one, and much better value.
Post #766344 1st Apr 2019 8:29am
HardCharger
What about an Allisport one? They're expensive but seem to be OK and even a bit bigger than the factory units with no plastic bits.
I was actually considering them when I had a radiator leak scare that just turned out to be a hose that was not reconnected properly.
Post #766472 2nd Apr 2019 2:52am
UtilityTruck
Does the factory one have the crappy plastic end tanks like the intercooler? Those seem to be a weak point, 2014 Keswick Utility 2.2
Post #766473 2nd Apr 2019 6:55am
HardCharger
Yes, I believe they do
Post #766478 2nd Apr 2019 8:19am
jst
Your genuine 14 plate one leaks after 5years which to me would say genuine are not worth the extra £££·
I fitted an all makes one to my 07 plate 2 years ago, fraction of price and all ok. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #766480 2nd Apr 2019 8:38am
HardCharger
Does the All Makes one have the plastic bits too?
Post #766482 2nd Apr 2019 9:10am
Advanced Factors
Site Sponsor
United Kingdom 1994 Defender 90 V8 Petrol SW Corris Grey
Puma Radiator
Hi Howard,
We have this available from stock.
Please follow link below.
Reagrds Paul.
https://www.advancedfactors.co.uk/pcc00102...1179-p.asp
PDK000100 Radiator Defender Td5 & Puma Nissens OE Quality
MPN: PDK000100, 64311A
WARRANTY: 2 Year Warranty
Brand: Nissens
£156.17 Inc. VAT
£130.14 Ex. VAT
 Paul Redding
+44 (0)23 8052 2760
Site Sponsor for Aftermarket Parts
Post #766494 2nd Apr 2019 10:17am
It was a Nissens radiator that I fitted (see post above). I couldn't remember the name, but the moment I saw the name it came back.
I have been completely satisfied with the one I fitted, it is every bit as good as the original Landrover one (and has already lasted longer that the factory radiator).
Post #766496 2nd Apr 2019 10:43am
jst
yes Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #766498 2nd Apr 2019 11:05am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I believe Nissens is the OEM for Land Rover.
Mine is the original LR one which is now 14 years old, Quite happy with that so I will replace with the OEM Nissens one.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #766508 2nd Apr 2019 12:27pm
Howard
Thanks for all the posts, rad on order from Paul at Avanced Factors
Post #766902 4th Apr 2019 7:10pm
agentmulder
Kuwait
Understand you've made your purchase, but another bit of 'anecdata' for those who visit this thread in the future:
I got Allmakes 'OEM', no thoughts of 'what is this junk!?' when I inspected it (that I've had with other aftermarket parts) and it's been working fine since install. Solved the bowel problem, working on the consonants...
Post #766987 5th Apr 2019 11:43am
