Home > Puma (Tdci) > OK to reuse engine oil?
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
Hi all,
The wife drives a Range-rover Evoque which suffers from oil dilution.
Subsequently, between very regular oil changes & services I siphon off excess engine oil.
I was wondering whether I could add a few liters to the defenders fuel, so that it doesn't go to waste.
The car in question is a 2009 2.4 TDCi 110 with 60k miles on it. It's also my daily driver, so I don't want to do anything detrimental to the engine!
Thanks!
Post #765798 28th Mar 2019 1:54pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Not a good idea..
Post #765803 28th Mar 2019 2:18pm
Roy5695
Just no... modern common rail diesels do not like anything other than diesel. Even some other less refined diesels in foreign regions can play havoc with injectors and the injector pump. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #765805 28th Mar 2019 2:38pm
blimbug
Glad I checked!
Best way to get rid of used engine oil? Trip down to the local tip?
Thanks!
Post #765806 28th Mar 2019 2:49pm
MartinK
I used to do this on my old Disco. After changing oil on Disco, Volvo, Motorbike, Lawn Mowers, I had a LOT spare/used oil every spring. Bought a filter off ebay, and used it in the Discovery (about 1 litre to every full tank). NEVER had a problem, and I bought the vehicle new, and owned it for 187,000 miles. Mechanically it was still A1 when I sold it.
Not sure I would do it in a later vehicle with CAT, DPF etc...
Now I take the old oil to the council tip for re-cycling. In fact I have at least 20 litres now (just changed the oil on the GF's Astra... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #765808 28th Mar 2019 2:57pm
Roy5695
Your local tip should take it. Best to check online before you go though Thumbs Up 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #765809 28th Mar 2019 2:59pm
discomog
You could send it to our local chippy, they are in desperate need of an oil change. Whistle Not a good idea to put it in your Defender, don't we have enough problems with them already. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #765814 28th Mar 2019 4:26pm
LR90XS2011
great for painting your fence DEFENDER 90 TDCI XS,
Post #765829 28th Mar 2019 5:46pm
Illegal for painting your fence.
Post #765834 28th Mar 2019 6:40pm
dorsetsmith
Re: OK to reuse engine oil?
blimbug wrote:
Hi all,
Thanks!
/www.surreycc.gov.uk/waste-and-recycling/community-recycling-centres/woking
Post #765842 28th Mar 2019 7:25pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Some folk slap it onto their chassis for protection, but if you can’t put it onto your fence like Blackwolf suggests perhaps
that is illegal too.......maybe someone can advise?
Post #765867 28th Mar 2019 9:55pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Most things are illegal these days, and getting worse Big Cry
Post #765884 29th Mar 2019 12:17am
Well it is carcinogenic and environmentally damaging so it isn’t surprising. It then also has the capabilities of contaminating land, and watercourses. Then to the water table and ultimately drinking water and habitat for wildlife. Anti freeze isn’t too dissimilar either and rightly should be disposed of correctly. However, local authorities deliberately make things as difficult and as expensive as they can!
I expect garages would take it too for an environmental fee. No Guts, No Glory.
Post #765885 29th Mar 2019 12:24am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
If you put it into a clear container you may find that the fuel and oil separate. then you can siphon off what you want.
I know petrol and diesel mix separates, so maybe the diesel/oil mix will also. I got hold of 50l from a miss fuelled car many years ago, after leaving it in a clear container for a few days I could suck out and use the petrol. 1953 80"
1987 mini city e
2011 90"
Post #766018 29th Mar 2019 9:34pm
Whitcliffian
I have just caught up on this thread & it caused me to remember something from my time in Africa. In the early ‘eighties I worked in Angola. It was on some mines there & the company involved extensively used Series L/R’s, Fuscas, (Brasileiro VW Beetles) & CAT earthmoving equipment as well as lots of other machines & vehicles.
Conditions were challenging. Parts were reused on a very regular basis to the extent that the scrap yards were well visited. My anecdote is that the mechanics said they did sometimes reuse engine oil when doing a first service. I think they thought it was of a better quality with it originating from UK when compared to the locally sourced engine oil. The locally sourced engine oil was readily available in the workshops so presumably it was a question of preference. I can only remember the mechanics doing it at a first service.
I am not suggesting that anyone does the same today.
Post #767634 8th Apr 2019 3:35pm
