Home > Puma (Tdci) > OK to reuse engine oil?
Page 2 of 2 <12
dgardel
Italy
Re: OK to reuse engine oil?
blimbug wrote:
Hi all,
The wife drives a Range-rover Evoque which suffers from oil dilution.
Subsequently, between very regular oil changes & services I siphon off excess engine oil.
I was wondering whether I could add a few liters to the defenders fuel, so that it doesn't go to waste.
The car in question is a 2009 2.4 TDCi 110 with 60k miles on it. It's also my daily driver, so I don't want to do anything detrimental to the engine!
Thanks!
Oil dilution mean diesel fuel on it!
Oil loose the 70% of the lubricating properties
your engine will not be happy.
You can use 2 stroke oil on the fuel. 2SO oil is made to be 100% burnt, the "normal" engine oil would leave too much combustion residue Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #768102 10th Apr 2019 10:41pm
Page 2 of 2 <12
