Home > Maintenance & Modifications > 2004 110 TD5 XS Rear Brake Discs
bankz5152
Im needing to replace my rear discs shortly but not 100% on what ones I need. Are the rear discs the same for models with ABS and without as mine has ABS.
Was going to go for these if they are right!
https://www.paddockspares.com/ftc1381ap-re...kheed.html
Thanks! Instagram @defender_ventures
Empire Tuning - Agent
Post #765597 27th Mar 2019 7:08am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
The part number you need is SDB000330 put that in the search box at Paddocks and it brings up various options of makes.
They have the hole for the ABS phonic wheel to bolt to.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #765638 27th Mar 2019 12:40pm
dorsetsmith
LR018026
This part supersedes SDB000330 and FTC2805
Post #765641 27th Mar 2019 12:59pm
bankz5152
Excellent.thank you.
What is it the ABS sensor reads on the rear? Instagram @defender_ventures
Post #765720 27th Mar 2019 8:21pm
dorsetsmith
FTC1379
Ring-pulsar antilock brakes
if you got by one id sit down and stiff drink Shocked
Post #765724 27th Mar 2019 8:35pm
