Home > Maintenance & Modifications > 2004 110 TD5 XS Rear Brake Discs |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Im needing to replace my rear discs shortly but not 100% on what ones I need. Are the rear discs the same for models with ABS and without as mine has ABS.
Was going to go for these if they are right! https://www.paddockspares.com/ftc1381ap-re...kheed.html Thanks! Instagram @defender_ventures Empire Tuning - Agent |
27th Mar 2019 7:08am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 |
The part number you need is SDB000330 put that in the search box at Paddocks and it brings up various options of makes.
They have the hole for the ABS phonic wheel to bolt to. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
27th Mar 2019 12:40pm |
LR018026
This part supersedes SDB000330 and FTC2805 |
27th Mar 2019 12:59pm |
Click image to enlarge FTC1379 Ring-pulsar antilock brakes if you got by one id sit down and stiff drink |
27th Mar 2019 8:35pm |
