Home > Technical > Td5 new steering pump , pipe don’t fit |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5843 |
Maybe your local hydraulic place could make you a flexi pipe up with the correct ends? 1999 Defender TD5 110
14th Mar 2019 10:04pm |
As above may be your best bet. Was in pretty much the same position a couple of years ago when I snapped the same part on the pump body. I couldn't find the right part that screws into the pump for love nor money and ended up buying another secondhand pump from a breaker.
14th Mar 2019 10:54pm |
gtmotorsport Member Since: 29 Jun 2016 Location: Cornwall Posts: 97 |
I maybe completely wrong, but from the photo the pump looks to have a threaded adapter already inserted. Is it possible this needs to be removed for your pipe to be installed?
15th Mar 2019 7:11am |
Click image to enlarge have read below https://www.defender2.net/forum/topic15873.html?view=previous |
15th Mar 2019 8:33am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Also https://www.defender2.net/forum/topic15746.html?highlight=pas 1988 90 Td5 NAS soft top
2015 D90 XS SW |
15th Mar 2019 12:21pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
Spooky that it's me that's the starter of both those threads!
I /may/ have an old pump in the garage.... I'll take a look when I get in. If it's got the correct union on it you're more than welcome to it Razz... pass it on and all that. |
15th Mar 2019 3:41pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
Hello everyone , many thanks for all your fantastic replies diesel Jim , if you have the correct union , i’m more than willing to send ya some monies for it
Ady |
15th Mar 2019 5:32pm |
Just had a rummage around the garage....
It was the water pump thing I had off the front of a Td5 alterntor. sorry. not the PAS pump I thought I had. |
16th Mar 2019 5:50pm |
No worries Jim , thanks for looking , I have purchased another pump , so all will be sorted soon , thanks everyone
16th Mar 2019 7:08pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
I think that'll actually be a vacuum pump then, not a water pump! |
16th Mar 2019 8:26pm |
