Home > Technical > Td5 new steering pump , pipe don’t fit
razz
2001 Defender 90 Td5 PU Caledonian Blue
Hello everyone , i’ve Fitted a new PAS pump to me defender , but the pipe does not fit , so I must have got a disco 2 pump , unfortunately i’ve binned my original defender pump , does anyone know if I can buy the defender part to screw into the pump ? Or am I best heading to eBay to get a cheap pump and take it off that ??? I do not wish to strip it all out again if I can help it
Post #763480 14th Mar 2019 7:00pm
excossack
Maybe your local hydraulic place could make you a flexi pipe up with the correct ends? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #763533 14th Mar 2019 10:04pm
JWL
As above may be your best bet. Was in pretty much the same position a couple of years ago when I snapped the same part on the pump body. I couldn't find the right part that screws into the pump for love nor money and ended up buying another secondhand pump from a breaker.
Post #763538 14th Mar 2019 10:54pm
gtmotorsport
United Kingdom 2006 Defender 110 Td5 CSW Zermatt Silver
I maybe completely wrong, but from the photo the pump looks to have a threaded adapter already inserted. Is it possible this needs to be removed for your pipe to be installed?
Post #763549 15th Mar 2019 7:11am
dorsetsmith
Post #763559 15th Mar 2019 8:33am
Martin
Site Admin
Also https://www.defender2.net/forum/topic15746.html?highlight=pas  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #763597 15th Mar 2019 12:21pm
Spooky that it's me that's the starter of both those threads!
I /may/ have an old pump in the garage.... I'll take a look when I get in.
If it's got the correct union on it you're more than welcome to it Razz... pass it on and all that.
Post #763637 15th Mar 2019 3:41pm
razz
Hello everyone , many thanks for all your fantastic replies Thumbs Up diesel Jim , if you have the correct union , i’m more than willing to send ya some monies for it
Ady
Post #763666 15th Mar 2019 5:32pm
Just had a rummage around the garage....
It was the water pump thing I had off the front of a Td5 alterntor. sorry. not the PAS pump I thought I had.
Post #763850 16th Mar 2019 5:50pm
razz
No worries Jim , thanks for looking , I have purchased another pump , so all will be sorted soon , thanks everyone Thumbs Up
Post #763864 16th Mar 2019 7:08pm
I think that'll actually be a vacuum pump then, not a water pump!
Post #763877 16th Mar 2019 8:26pm
