![]() | Home > Technical > Central locking problem |
check driver door wiring between door and A-piler, central locking needs feed back from door lock
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5838 ![]() ![]() |
Watch when you lock it. Are any of the lock buttons slow to go down? If yes that’s your problem.
That sounds very much like a sticky mechanism, i.e. it tries to lock but meets resistance and so doesn't completely engage. You might get away with lubricating the latch mechanism with a decent penetrating oil but if that doesn't work then you'll need to remove the door card and look at the linkages. Darren
nick345345 Member Since: 05 Dec 2016 Location: Dunbar Posts: 71 ![]() ![]() ![]() |
I had a similar problem, more details on this thread
https://www.defender2.net/forum/topic63776.html |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4754 ![]() ![]() |
Had this problem with a 5 door. It was a broken wire going into the driver's door.
I had a the "sticking" problem too, i.e. one of the push buttons would not go down. All of the other doors would lock. The alarm only went off if I opened the door with the sticking button. So from that I would say your problem is a broken wire. All of the wires are in a sleeve. Any luck the brake will be between the door and the footwell side. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Found this, it could also be your problem.
https://www.defender2.net/forum/topic63776.html 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49 ![]() ![]() |
Same issue on mine which I need to look into
If it is not either of the simple fixes above it will be the "door actuator". This is what pushes the mechanism that gets the buttons to go down. 1982 88" 2.25 diesel
Will osborne Member Since: 12 Jan 2017 Location: West midlands Posts: 14 ![]() ![]() ![]() |
I took both door cards off checked the wires on both doors and checked the mechanism on the door lock seems to be free, but took it apart and spray WD40 on it to clean it.
I have notices that in the history it has had a new driver door actuator and passenger door lock mechanism which was last year. Could the passenger side actuator be the problem Thanks for you replies Regard Will |
Yep could well be. Take the door card off and press lock and see if things move smoothly. 1982 88" 2.25 diesel
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Old thread, but I've had an issue with one locking mechanism on mine. It's on a door where I previously repaired the broken wiring between B pillar and the door.
The door lock button will go down when the central locking is activated fine but won't pop all the way up when you open the vehicle. I also have the alarm (BBUS) sound when I start the vehicle when the weather's cold, so was wondering whether my battery doesn't have enough amps at start up (it's 6 years old) to move a stiff mechanism. The other doors open fine, although the rear door's actuator is slow and whines a little. Is my battery the problem? |
Well.....it ain’t the battery.
In my experience of the same symptoms was that the actuator in the door had become lazy, and a new one sorted it.
Rich01483 Member Since: 26 Jul 2021 Location: Uk Posts: 15 ![]() |
This resolved the issue for me actually, and am easy fix, so worth a check |
