Home > Maintenance & Modifications > Td5 transfer box and axle oils ? |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Is there a 75w-80 meeting API GL4 for the td5 gearbox you recommend otherwise I might try the Millers trident you linked too as it's a lot cheaper than the landy stuff. |
4th Feb 2019 11:38am |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 |
Yes there is plenty these days. You can also use one that meets GL4 and GL5 as it just means it has the synchro friendliness of GL4 with the load bearing ability (ep) of GL5.
Have a browse through these https://www.opieoils.co.uk/c-670-75w-80-gear-oil.aspx Cheers, Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
4th Feb 2019 4:01pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
I use a garden sprayer. The type that holds about 10ltrs and you pump up the pressure, then press lever on a wand to release fluid.
5th Feb 2019 8:29pm |
Are you putting the oil in the sprayer then and cleaning it out each time you switch oils? Are you just using the sprayer end or taking that bit off some how as I figured oil will be too thick?
This sort of thing https://www.screwfix.com/p/sx-cs5-white-bl...5ltr/7490x |
5th Feb 2019 8:48pm |
Yes that is the same type of sprayer. I empty it if required between jobs, and let the oil drain from the filling tube. But I don’t worry about cleaning it as all oils combine, not much gets left in it just residual bit. Also the oils on a Td5 Def aren’t that different to each other. I’ve just removed the spray tip off the end and bent the tube into more of a hook. Works really well.
5th Feb 2019 10:35pm |
Finally got round to ordering the gearbox oil for now, I've gone with the Millers Trident 10w-40.
13th Mar 2019 10:01am |
So far so good actually feels like a different gearbox, very smooth changes now.
22nd Mar 2019 11:46am |
