Home > Maintenance & Modifications > Rusty Wheel Nuts
Honcho
Ireland
Rusty Wheel Nuts
I have put on a set of modulars on the 110 and I used some black nuts that I got for it but the flipping nuts are rusting and look crap. What have people done to sort this out?
Is the best solution to get plastic caps for the nuts?
Post #762969 11th Mar 2019 11:13pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Post #762976 12th Mar 2019 6:19am
ericvv
They look like standard steel nuts as used on Defender Wolf or standard steel wheels. You can buy a set of genuine black nuts, from Dan at Duckworthparts on here for instance. I use those black genuine steel nuts in winter on my Wolf winter wheels, 9 years in a row now and no rust at all.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #762979 12th Mar 2019 6:58am
Grouse
My genuine nuts went rusty too - I took them off wire brushed and sprayed with black Stove Paint as it doesn’t need primer, matches the finish and seems to last so far
Post #762980 12th Mar 2019 7:01am
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
slightly off topic, but have realised what a cool name that could be, so from now on I would like to be called Rusty wheelnuts
Thanks
Rusty Thumbs Up
Post #762995 12th Mar 2019 8:36am
Honcho
Ireland
Thanks all. Think I will have to source nut caps of some sort sat the tops of the studs are rusty too so no point having shiny nuts and a rusty bolt Whistle
Post #763042 12th Mar 2019 1:14pm
