![]() | Home > Maintenance & Modifications > Rusty Wheel Nuts |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Would these do the trick:
https://www.ebay.co.uk/itm/Land-Rover-Stai...SwpoNanPr~ |
They look like standard steel nuts as used on Defender Wolf or standard steel wheels. You can buy a set of genuine black nuts, from Dan at Duckworthparts on here for instance. I use those black genuine steel nuts in winter on my Wolf winter wheels, 9 years in a row now and no rust at all.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 530 ![]() |
My genuine nuts went rusty too - I took them off wire brushed and sprayed with black Stove Paint as it doesn’t need primer, matches the finish and seems to last so far
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
slightly off topic, but have realised what a cool name that could be, so from now on I would like to be called Rusty wheelnuts
Thanks Rusty ![]() |
Honcho Member Since: 09 Mar 2014 Location: ^^^ Posts: 49 ![]() ![]() |
Thanks all. Think I will have to source nut caps of some sort sat the tops of the studs are rusty too so no point having shiny nuts and a rusty bolt
