Home > Td5 > Main beam lights out
Martin 01
Started having a problem with my main beam lights.
Could put them on & sometimes they would just go off all by themselves. Could pull & push the light stalk & they would come back on.
The problem now is that they aren’t coming on at all now.
Read up on some of the faults people have had so collected a new stalk today.
Dismantled around steering column & removed existing stalk. This felt and looked all ok.
Fitted new stalk anyway & lights still remained the same.
I have side lights on the first push of the stalk but no main beam on second push down on the stalk.
I do however have full beam & blue light that lights up on dash.
Took out the dash clocks & looked at & removed the pink relay that I think is related to the lights.
Couldn’t hear it clicking at all when I switched the lights on & off so thinking this maybe my next port of call.
Just popped out to check it tonight & lights came on as usual, pulled off the drive & 50yrds down the road they went off.
Stalk back & forth & they came back on for short while thenoff again. Kept doing this few times & then back to no main beam.
I’m no wizard with the multimeter either.
Any ideas welcome fellas Thumbs Up
Post #762737 9th Mar 2019 10:41pm
grafty99
I had similar symptoms. It was the pink relay that had gone faulty on mine Thumbs Up
Edit: I misread main beam and full beam. Having re read and replaced main with dipped it makes much more sense.
I think it could be your main lighting switch. As in the little one lower down, not the main one that also controls the indicators and horn Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #762740 9th Mar 2019 11:25pm
Martin 01
Already replaced that Grafty Thumbs Up
Next I was going to replace the pink relay as these seem main offenders.
Post #762746 10th Mar 2019 8:28am
grafty99
I'd check by bridging the contacts in the relay base with some decent gauge wire and some large spade connectors Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #762752 10th Mar 2019 9:12am
Martin 01
Cheers Grafty, I’ll get my pal to give me a ya day as I’m no whizz with the multi meter.
Do you know which ones to bridge to test ?
Post #762754 10th Mar 2019 9:24am
grafty99
1990 Vogue SE
Post #762781 10th Mar 2019 1:10pm
Martin 01
Cheers Grafty I’m sure I can manage that Very Happy Thumbs Up
Post #762887 11th Mar 2019 1:31pm
Martin 01
All done back up & running.
All lights now working.
Just done same as you Grafty Thumbs Up
Thanks for the assistance, much appreciated. Bow down
Next question is any tips on sorting a squeaky clutch pedal.
Getting rather annoying when pressing & releasing clutch pedal.
It’s internal not the box.
Tried some GT85 which worked for a short while but it’s back now
Post #762947 11th Mar 2019 9:35pm
grafty99
Its probably the top pivot. Lube the pivot under the bonnet rather than in the cabin it can sound internal even if it is the pivot Thumbs Up
Also I replaced my relay but bridging it worked well until the new one arrived. Not sure it's really required though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #762961 11th Mar 2019 10:33pm
landy andy
I wouldn’t bother replacing the pink relay, either keep it bridged, by the bridging relay or bin the dip dim unit from the inner wing. Dip dim is something else to wrong, it’s not required and kills headlight bulbs by giving them a too low voltage.
And as mentioned lubricate the clutch pedal from the top of the pedal box not inside the vehicle Thumbs Up
Post #762968 11th Mar 2019 10:54pm
Martin 01
Cheers Grafty & Landry Andy.
All sorted now.
Thanks for all the help Thumbs Up
Post #763258 13th Mar 2019 7:17pm
