Home > Puma (Tdci) > Oil leak help |
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 |
Isn’t that just below the oil filler cap? Have you filled her up recently and missed the hole?
4th Mar 2019 8:42am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
It is below the filler but unfortunately not just miss filled. Had the engine steam cleaned to see what was happening. From what I've read the camshaft carrier does not have a gasket, just sealant. I'm wondering if this has sprung a leak??
4th Mar 2019 8:55am |
vacuum pump oil leak
https://www.defender2.net/forum/topic51106.html |
4th Mar 2019 10:33am |
Thanks but I don't think it is as higher up the engine. I checked around the pump and all dry.
4th Mar 2019 10:38am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2416 |
while ruuning your engine remove one end (air inlet side) of the PCV hose and check you get blowing air/gas Puma 110" SW
4th Mar 2019 12:47pm |
FinnSmith Member Since: 03 Dec 2019 Location: cheshire Posts: 4 |
Hi, I have the same issue? just wondering if you know what is it and how much it is to fix? |
3rd Dec 2019 12:08pm |
So I decided not to fix it as it was going to be expensive as you've got to take so much out to get to it. About a grand in the end. It's not enough oil dip down in my case. I simply spray a can of degreaser over that side of the engine and wash off with the hose once every 3 or 4 months and pre-MOT.
If you do decide to get it fixed please keep me posted as I'd eventually like to do it. J |
3rd Dec 2019 1:19pm |
Do you know what causes the oil leak? such as what seal/gasket or whatever?
3rd Dec 2019 1:23pm |
