Home > Td5 > Picture of Rear seat belt mounting in 90
mark13
United Kingdom 2004 Defender 90 2.5 TD HT Cairns Blue
I do not suppose anybody has any pictures of how they have fitted the seats belts for forward facing rear seats in a defender 90, especially how they fitted it with the rear side trim. The seat belts and mounting brackets I was thinking of using are the Exmoor trim ones, any useful tips?
Post #761124 28th Feb 2019 12:01am
Green&Gold
England 2004 Defender 90 Td5 XS CSW Willow Green
hi mark13
I came across this v useful link which contains a portion on the modification I think you are after.
The PDF can be found here:
https://www.defender2.net/gallery/albums/u...ersion.pdf
Post #761733 3rd Mar 2019 6:55pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Check out the thread about insurance cover in this section...be worried, be very, very worried Shocked
Post #761739 3rd Mar 2019 7:03pm
mark13
Thank you for the reply’s but I don’t think the link works, it just comes up with the link can not be found.
Insurance is something I’m very interested in when I spoke to the insurer (Aviva) they said as long as the seats count is below 6 and installed to the manufacturer spec they are fine with it
Post #761742 3rd Mar 2019 7:12pm
barbel jim
Declare the seats as a mod and they should be fine. A plan are and no extra charge in premium. There's a designated bracket that fits in the corner, which carries the reel and top mounting.
these are the kiddies Thumbs Up https://www.ebay.co.uk/itm/Defender-rear-s...3727115721
Eddited to add sorry Ive not got any pictures. I used genuine parts other than the arch plates. passed another MOT Saturday and hes was more than happy Thumbs Up Phil at OEM supplied all the bits, but a full kit seems readily available from others like YRM or LRI
Post #761748 3rd Mar 2019 7:46pm
Green&Gold
Post #761767 3rd Mar 2019 8:51pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
From Exmoor Trim. If I recall correctly it's a genuine LR part.
 Phil
Post #761783 3rd Mar 2019 11:00pm
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
On mine there is a bar under the wheel arch that the bottom of the seat belt bolts to through the floor. It’s attached to the rear bumper inside the rear wheel arch. I guess the floor itself wouldn’t be strong enough to retain the seat belt in the event of an accident so Land Rover reinforced it with a bloody great bar attached to the bumper / chassis! It’s a pig to get in and out! I know cos I fitted rear wheel arch liners and the bar had to be removed and then reinstalled to get them in.
Hope this helps?
Scrawf
Post #761815 4th Mar 2019 9:27am
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
I have the exmoor trim fwd facing rear seats fitted in the back of my TD5. Disclosed to my insurer (NFU) and no problems at all.
Post #761892 4th Mar 2019 6:09pm
petegoss
Any pictures of how you fitted the seat belt buckle (to the floor I assume?
Post #889470 6th Mar 2021 6:04pm
Orangesofa
It was integral to the seat... Phil
Post #889481 6th Mar 2021 6:55pm
petegoss
No help but thanks Phil, you must have the chamfered wheel arches
Post #889484 6th Mar 2021 7:01pm
Orangesofa
I don't actually - it is a van back with self cut windows, so square-edged arches.
I installed the loc and fold (earlier model) which has the buckle receiver attached to the seat rail. I'm not sure what the situation is nowadays but back then it was the only type approved one which would be insurable per se.
This pic is of current version of what I have.
 Phil
Post #889491 6th Mar 2021 7:12pm
